Endo on a narrower rim?- Mtbr.com
Results 1 to 6 of 6
    Reputation: dosboy's Avatar
    Anyone tried to mount an endomorph on a narrower rim like an echo trails? Im just wondering if it would narrow it down a bit to fit in the back of a 1X1???? I know the gazzi 3.0 on a large marge fits, with a little room to spare, in reality there is about 3.2-3" of space back there...Think a 3.7 endomorph on a 44mm rim instead of a 64mm LM would fit in the back???? Just wondering if any of you crazy AK riders have tried it before I invest the $$$ to see for myself....
    is buachail foighneach me
    Reputation: sean salach's Avatar
    while i was up there last week, with 26x3 tires on46mm rims in my karate monkey, i tried basically what you're saying there, and there's just no way in hell an endomorph is going to fit into a karate monkey as it comes. the 1x1 might have a little bit more clearance, but it would really need to be alot. height of the tire also comes into play. you would need clearance for a 29" tire in chainstay/seatstay length.
    there is a thread or two on here which describe pat irwin's 1x1, which he modified heavily with hacksaw, hammer and torch to fit an endomorph.
    yeah
    Ive seen his mod, unfortunately I dont weld. I had a 1X1 set up with LM rims, and an endo up front with a 100 mm pug fork, I just hated having the gazzi in the back..To heavy, and the tread was all wrong. I just was thinking if an endo could possibly fit back there on a narrower rim that might make it close to a pug, without all the extra cost...But it just might not be possible without dicking around with the frame...(BTW I think 1X1 frames fit 29er wheels)
    Feb 2007
    Gazzi Tread
    You've probably thought of this, but because of fork/rim/tire issues I'm running a gazzi up front that I've modified heavily with a sharp pair of side cutters to remove some of the treads completely and also a dremel tool to modify the treads I've kept. It has the bonus of losing some of the weight also.
    yeah I have but the damn tire weighs friekin 4 lbs! hard to push esp in snow even after hours of shaving knobs off the thing...Just need endo tread period
    Reputation: juxtaposition's Avatar
    Yes. No.
    Yes the 1x1 frame will fit 29ers... No the 1x1 will not fit an Endomorph tire without modifying the frame, even with snowcat rims.
