The Bivy Buritto- Mtbr.com
Results 1 to 8 of 8
    Caveman
    Reputation: Bearbait's Avatar
    The Bivy Buritto
    Sick of stuff sacks?
    hot sauce not included but the -20 down bag, bivy sack and ridgerest are.
    Really simple.
    Caveman
    bike attachments
    bla bla bla
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by Bearbait
    bla bla bla
    Great idea and execution Eric. You're a bit ahead of your time.
    MC
    is buachail foighneach me
    Reputation: sean salach's Avatar
    when i go touring, i usually roll everything up together in a similar fasion, then put them in a trash bag and use loose straps to compress them, bungees to attatch them to the rack. this looks alot cleaner and easier.
    Caveman
    Thanks - the goal was to do away with the rack and have an easily deployable & packable setup. My sleeping setup here is on the bulky side, the down bag is a long etc, so I think its on the higher end of size. If you have a Darkstar however all bets are off... you'd need it to be quite hourglass shaped or longer to clear the front tire. Those things are monsterous.
    Caveman
    The Sleeping Bag Sausage
    Another version I just finished, this one is more Sausage like - hence the name..
    Both sides roll down, 4 compression straps in addition to the h-bar attachments.
    Different concept all together from the Buritto.
    -20 Bag, bivy, pad all in there, then compressed to about half the diameter.
    Grillin' & Chillin'
    Reputation: speedsk8_ak's Avatar
    Nov 2006
    Bivy Bag
    I have a Goretex outer shell for my sleeping bag. Does that count as a Bivy Bag for the Susitna 100? It's a heavy duty military issue.
    Grill Meister
    "There were never any good old days
    They are today, they are tomorrow
    - Gogol Bordello
    Tim I do not see why not but then again I am not sure. Check with AK29 he is the one doing the gear check I think. I am useing a ThermoLite 2.0 Solo Bivvy Sack, it is light weight 6.65 oz (189 g) and cost effective $27
