want to put some road tires on my new guardian- Mtbr.com
Results 1 to 6 of 6
    Feb 2015
    I just purchased a new guardian and wanted to occasionally run it on the road. What would be required to get a second set of tires that were more close to a commuter tire?
    Sep 2014
    Just some new tubes to fit the tires. I would use a 700x35c or so for road riding. That's a good size most hybrids run.
    Feb 2015
    Quote Originally Posted by RSDSav View Post
    Cool thanks, what if I wanted to have a whole other set of wheels that I can pop on when I want to ride the roads. Is this common? Do I have just have to get a set of wheels that fits the 3x9 gears and size?
    Sep 2014
    Quote Originally Posted by nater317 View Post
    That is obviously the easiest and fastest way to switch the wheels. Remember you need a wheelset, disc rotors, 9 spd cassette, tires and tubes. This can be a pricey way to go but is a huge time saver if you swap around often.
    Apr 2014
    Have you tried putting 50-60 PSI in the tires it came with and riding them on the road?
    Feb 2015
    Quote Originally Posted by TMO8853 View Post
    I have not! I will try that first. Many thanks!
  1. Tires on Guardian 2.0
    By Dirt n Dust in forum Airborne
    Last Post: 06-04-2014, 08:54 PM
  2. Road Tires VS Dirt Tires?
    By benran44 in forum 29er Bikes
    Last Post: 05-16-2013, 11:18 PM
  3. Switching from off road tires to street tires...suggestions?
    By bpreachers in forum 29er Components
    Last Post: 04-13-2013, 10:35 PM
  4. Narrower tires for an older MTB? (off-road tires)
    By Medic Zero in forum Wheels and Tires
    Last Post: 09-10-2011, 08:25 PM
  5. Replies: 19
    Last Post: 06-06-2011, 03:01 PM
