Hobgoblin XO Brake Swap- Mtbr.com
Results 1 to 5 of 5
    Nov 2013
    Hey,
    I am finally fed up with the Elixir X9 brakes that came on my Hob XO. They are frozen again, which has happened at least once a year since getting the bike in 2014. I am thinking I'll swap them out for Shimano XT BR-M8000 brakes. I'll keep the Avid rotors which are fine.
    My question is whether I need any adapter, or if the calipers should go right onto the current mount. (The front currently has an adapter for the 180, the rear is direct-mounted to the frame for the 160).
    Also, any input on the brakes I'm choosing?
    Thanks, Chip
    Nov 2013
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    You should be able to swap right over without (usually) having to get different adapters. As far as brake sets, I have picked up two sets of Guides off of Pinkbike fairly cheap and are fantastic stoppers.
    Nov 2013
    Thank You!
    Jan 2014
    Quote Originally Posted by s0ul_chicken View Post
    Agree on the Guides, especially the 4 piston variety. I was given a set of Guides and swapped them in from my Level's and they're much better. If you get Guides, make sure to get the 2017 or later if they're take-offs since SRAM had piston issues seizing when they got hot with many before that.
    If, on the other hand, you're set on XT's spend the extra to get the 4 piston version, well worth it!
    I'm not going to get into the pissing match here but also be aware that SRAM and Shimano have VERY different modulation to the brake feel. I have a riding buddy who hates SRAM whereas I prefer the progressive feel of SRAM over the binary on/off feel of XT. Personal choice.
    Devinci Marshall Carbon 27.5+
    Colorado Springs, CO
  1. Hobgoblin vs. Hobgoblin XO
    By TulsaBiking in forum Airborne
    Last Post: 07-13-2014, 10:08 AM
  2. Airborne HobGoblin?
    By Lovespicyfood in forum Airborne
    Last Post: 07-04-2014, 02:07 PM
  3. Replies: 2
    Last Post: 01-28-2013, 12:27 PM
  4. HobGoblin X0 Info
    By BigDaddyFlyer in forum Airborne
    Last Post: 01-12-2013, 03:17 PM
  5. Airborne Hobgoblin FS 29er
    By jeffw-13 in forum 29er Bikes
    Last Post: 12-29-2012, 06:26 PM
