Going airborne- Mtbr.com
Results 1 to 16 of 16
Thread: Going airborne
    LUW
    LUW is offline
    Ped on BIG wheels
    Reputation: LUW's Avatar
    Listen! Going airborne
    Is it my impression or is it harder to catch more air with a 29er then with a 26er ?
    My 29er is lighter then my SPZ '95 Stumpy, both are HT, but I can bunny hop more easily and catch more air over fast bumps with it then with my Flash. Is it just my impression, a problem with that little part that goes over the saddle or because of the frame (carbon metal matrix of the Stumpy)?
    Really not an issue, I'm just curious .
    Cheers!
    Luciano
    Brazil
    Reputation: thickfog's Avatar
    Oct 2010
    Your findings match mine.
    CRAMBA Chairman
    LUW
    LUW is offline
    Ped on BIG wheels
    So why is it, the bigger wheels make the bike less "springy"?
    Cheers!
    Luciano
    Brazil
    Jul 2003
    It's not just the bigger wheels. It's a combination of things, geometry, wheels, etc. Most 29ers have the front wheel set further forward to prevent toe overlap, longer chain stays to accommodate the big wheel, etc. Basically all the tweaks that have gone into 29er geometry over the past few years that make them a reasonably nimble fun bike to ride, have also conspired to keep them rather closer to the ground than a 26" bike.
    Anyway, your not alone. I've found that a 29er isn't as easy to get airborne. It simply isn't something that most wagon wheelers are designed for.
    Good Dirt
    Is it Friday yet?
    Reputation: kwrides's Avatar
    Oct 2010
    What Squash said. It's the geometry.
    Reputation: esundell90's Avatar
    Dec 2009
    I figured this was the case. I noticed the same thing. I sort of figured the larger wheels factored into it. 29's roll over things, you don't need to jump them as much from what I've found.
    -Eric
    Keeping the hardtail dream alive, one ride at a time.
    LUW
    LUW is offline
    Ped on BIG wheels
    Thank God it's geometry! I was fearing it was age!
    Cheers!
    Luciano
    Brazil
    The longer wheelbase is the big inhibiter, longer lever arms with the longer chain stays reduce the ability to spring off the rear end like most people
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    I don't have any problem getting airborne on my 29ers. I do agree that it may be easier on a 26" though...even easier on a bmx bike....perhaps easiest on a pit bike
    Forget you are on a 29er and just do it!!!! It takes a little different technique and control, but being airborne on 29ers is fun!
    I repair Carbon Fiber frames.
    http://twobrotherscycleworks.blogspot.com/
    Reputation: azjonboy's Avatar
    Ride Phil's World. Air a plenty!!
    If you're lucky enough to be in the mountains,
    you're lucky enough.
    Professional Crastinator
    Reputation: Fleas's Avatar
    Yeah, I'll say that my old aluminum 26" Stumpy could bunny hop pretty good (not that I am any good at it), but my steel MCR9 definitely has some *POP* in the frame - like a big spring. If my timing is good I can launch it off tiny (like 1" root) stuff and get way higher than a bunny hop. The payoff is disproportionately big. But those slightly longer chainstays make it a little harder to hop without any assisting roots/rocks.
    Just plain jumping - which I'm also not very good at - seems to be just as easy.
    -F
    Quote Originally Posted by Mr.SBC View Post
    Thats a misconception.
    Give a 29er to a DH pro such as Brian Lopes and he can most likely jump it close to, if not just as good as if he was on a 26".
    But for normal folks like us though, it is not as easy to J-hop the bigger wheels. Is still doable with some practice.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    When J hopping, I find I have to get the bike 1.5 inches higher than a 26.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    LUW
    LUW is offline
    Ped on BIG wheels
    Yeah, that's my impression too: it seams I have way more bike to pull up, therefor I can't get the tires as high as I would get with the Stumpy.
    The size and geometry offer a very reasonable explanation, but wouldn't the fact that now I'm on a carbon frame also play a part? Since that metal matrix frame of the Stumpy is so rigid?
    Cheers!
    Luciano
    Brazil
    Old Punk
    Do a vimeo or YouTube search for Chris Akrigg. The dude rides street, trials and freeride on all kinds of bikes. His vids on a flatbar 700c fixie are insane.
    '09 Specialized Rockhopper expert 29
    Born 26" trials
    '07 Specialized Allez
  1. Airborne...YTF not?
    By 2ndgen in forum Airborne
    Last Post: 09-14-2011, 03:49 PM
  2. airborne
    By robuler in forum Airborne
    Last Post: 09-11-2010, 03:59 PM
  3. $PAM: Airborne B-29
    By kenyon in forum Airborne
    Last Post: 03-18-2005, 04:21 PM
  4. Airborne, anyone?
    By bluronthetrails in forum Airborne
    Last Post: 09-21-2004, 09:55 AM
  5. Airborne?
    By sircrashalot in forum Airborne
    Last Post: 09-01-2004, 12:31 PM
