Goblin Bottom Bracket Spacers Placement?- Mtbr.com
Results 1 to 2 of 2
    Jan 2015
    Pulled the GXP bottom bracket out of my Goblin last night to inspect. This is the first time taking it apart and I noticed both of the spacers were on the drive side, rather than one on each side, as seen in the link below. Is this normal?
    https://sram-cdn-pull-zone-gsdesign...._cranksets.pdf
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    Quote Originally Posted by Grouch51 View Post
    They both can go on either side, or one on each side. This gives you a bit of leeway when it comes to chain line. Since I run a RaceFace N/W, I have mine both on the non-drive side so I get more even wear on the chainring.
  1. Bottom bracket spacers on SB-95a
    By savechief in forum Yeti
    Last Post: 05-23-2014, 07:14 AM
  2. SRAM GXP bottom bracket spacer placement
    By natzx7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2012, 07:53 PM
  3. Bottom bracket spacers
    By dreednya in forum Ibis
    Last Post: 04-26-2012, 10:38 PM
  4. Bottom bracket placement? Front or rear Triangle?
    By SuperSlow35th in forum Shocks and Suspension
    Last Post: 12-12-2011, 09:33 PM
  5. O ring placement on King bottom bracket question
    By Jaybo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-17-2011, 10:22 PM
