Goblin Bottom Bracket- Mtbr.com
Results 1 to 5 of 5
    Feb 2014
    After a couple of happy years of riding my black Goblin, I've worn out the bottom bracket. Can someone point me to a correct replacement? Preferably on Amazon, so I can get it before Labor Day with Prime I want to make sure I order the right part since I'm planning on riding next weekend.
    Also, I'm a bit surprised that it has worn out as quickly as it did. I probably only have ~1000 miles on the bike and I was under the impression that a BB generally lasts twice that. I've been using it as my daily commuter for the last couple of months and ridden through some pretty heavy rains, so that might have something to do with it. Anyone have any suggestions for protecting the bearings? When I pulled it, the threads were completely dry, so a bit of grease might go a long way with the new one.
    Thanks in advance.
    Feb 2014
    This is what I've been looking at, but I noticed several other options that had size choices... I know I need English threads but that's about it.
    http://www.amazon.com/Truvativ-Team-...B7J1JTZ85741GN
    Reputation: toddre's Avatar
    Quote Originally Posted by J Moss View Post
    Amazon.com : Truvativ GXP Team Bottom Bracket Cups : Bike Cranksets And Accessories : Sports & Outdoors
    Yeppers. That should work for ya
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    Thanks in advance.
    Sounds about right, I replaced my BB 1200 miles ago, and mine is already making noise. They aren't that expensive, but you could also look into the ceramic versions for longer life.
    Apr 2014
    My BB started making noise and I could feel a clunk every rotation only after a couple months of riding. I removed the cranks and the bottom bracket was so loose I could rotate it back and forth by hand. I purchased the BB tool and torqued to recommend setting and everything was perfectly smooth.
  1. Goblin Bottom Bracket Spacers Placement?
    By Grouch51 in forum Airborne
    Last Post: 08-21-2015, 06:38 AM
  2. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  3. ex7 bottom bracket
    By frana in forum Trek
    Last Post: 03-03-2015, 08:02 AM
  4. Goblin Bottom Bracket
    By TMO8853 in forum Airborne
    Last Post: 09-26-2014, 09:15 PM
  5. Bad Bottom Bracket
    By drjay9051 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-07-2014, 06:47 AM
