Goblin- Mtbr.com
Results 1 to 9 of 9
Thread: Goblin
    Aug 2018
    Goblin
    This is my first ride after going 1x. It s been an amazing ride so far. The bike is quieter and a lot less to think about. Why didnít I do this earlier
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    Looks fantastic!!
    Mar 2016
    Nice! I probably will do this soon too. Do you know the parts you used? My biggest question would be BB compatibility or chain line w whatever 1x drivetrain I get.
    Aug 2018
    I just bought a 104bcd 30t chainring from raceface. Then removed all the parts for front derailleur and shortened the chain.
    Mar 2016
    Thanks for the info. I probably need easier than 30/36 to climb though, so would also try to get a cassette. Then would have to figure out how many teeth X7 derailleur can handle. Which I can see turning into a drive train!
    Aug 2018
    Thatís where u am at now, this was an experiment to see if I liked 1x. Plan is to upgrade my drivetrain to a GX 1x11 with sunrace cassette 11-50 and get a 32-34 for the front
    Mar 2016
    I went 1x10 too. Absolute Black 30t oval and a OneUp 42t cog addition to X7 cassette. So now my granny is 30/42 which is good for improving my strength up 10-15% climbs that I used to use 22/36. Also using a KS SpeedUp manual dropper. Bike is ~25 lbs, feels great.
    Apr 2014
    Hi I have a green goblin also and was looking at the new goblin for my girl, can someone explain the difference from the v2.0 SRAM X7 2◊10 and the 1x11 drivetrain? We mostly ride hard pack trails and bike paths, I would actually like alittle more top end speed.
    Mar 2016
    The Shimano SLX drivetrain that it comes with looks to be 30t front and 11-46t back. For top end gearing, you divide the front toot number by the lowest cassette tooth number. A 30/11 for the hardest gear is considered pretty decent...you will spin out on mild hills, but your speed will be like 20 mph which is probably fast enough. However, I believe the older Goblins with 2x10 came with 38/11...so a much harder gear.
    Additionally 30/46 for easiest gear is pretty good too. I have to work hard to climb 10-15% long fireroads with a 30/42. I'd say the current v3 Goblin they're offering looks like a good deal. At first glance the only things I would change would be to buy a 60 mm stem, maybe wider bars, and change the tires to tubeless Maxxis 29x2.35 Forekasters. Also, an oval chainring might help stretch both ends of the gear range.
  1. Goblin vs Goblin Evo
    By sti2.5ldohc in forum Airborne
    Last Post: 01-16-2014, 08:31 AM
  2. Goblin vs....... Goblin XO
    By Jem7sk in forum Airborne
    Last Post: 05-03-2013, 06:47 AM
  3. Goblin vs Goblin XO
    By drjay9051 in forum Airborne
    Last Post: 02-28-2013, 05:35 AM
  4. Goblin or Goblin XO
    By drjay9051 in forum General Discussion
    Last Post: 02-26-2013, 09:19 PM
  5. Replies: 12
    Last Post: 11-16-2012, 07:39 AM
Members who have read this thread: 4
