goblin 1.0 quanta front hub conversion from 9mmQR to 15mm axle- Mtbr.com
    Jul 2013
    hey guys, I have a set of wheels from a goblin 1.0 and I am trying to convert the front hub from the original 9mm qr setup to 15mm thu axle. I have already removed the end caps and center axle. it looks as though the inside diameter of the stock bearings are 15mm, so I think all i need is different end caps to accommodate the larger axle. am I correct? does anyone happen to know where i can find the end caps I need. I did a search on ebay and google and I did find some 15mm end caps but i'm not exactly sure what I need because most for the pics of the adapters I found do not show the back side. the hub says "QUANTA" and the endcaps I removed say "QUANDO, sealed cartridge bearing" any help would be greatly appreciated. thanks.
    JJ
    Jul 2013
    here are some pics
    Attached Thumbnails Attached Thumbnails goblin 1.0 quanta front hub conversion from 9mmQR to 15mm axle-20160101_175656_resized.jpg
    goblin 1.0 quanta front hub conversion from 9mmQR to 15mm axle-20160101_175805_resized.jpg
    goblin 1.0 quanta front hub conversion from 9mmQR to 15mm axle-20160101_175857_resized.jpg
    Reputation: BigDaddyFlyer's Avatar
    Unfortunately, those hubs aren't designed to be converted to a thru-axle set-up.
    Jeremy
    Jul 2013
    bummer. thank for the reply. I appreciate it.
  1. Replies: 6
    Last Post: 06-02-2015, 07:36 AM
  2. Hub conversion 9mm QR to 15mm Thru axle
    By Rmn in forum General Discussion
    Last Post: 10-18-2013, 10:31 AM
  3. from 142+ to 135mm & 15mm to 9mmqr?
    By zippy895 in forum Trek
    Last Post: 11-29-2012, 01:09 PM
  4. 15mm axle conversion
    By warrior737 in forum Wheels and Tires
    Last Post: 10-01-2012, 11:25 AM
  5. Replies: 3
    Last Post: 03-08-2011, 05:11 PM
