Which frames will swap out with goblin parts?- Mtbr.com
Results 1 to 3 of 3
    May 2012
    If I am unable to sell my Goblin I am going to replace the frame with an XL. Since they are out of 22" silver frames, anyone have any insight on what frame these parts will best swap over?
    Thank you
    Feb 2013
    I switched parts to a Niner EMD previously. Be mindful if you go to a bigger size you may need new cables and housing and will have to check that your brake hoses will be long enough.
    Jul 2013
    G
    Quote Originally Posted by coxinio View Post
    This is spot in. I went from a medium guardian to a large silver goblin frame. It heavily upgraded now but when I first did the swap I needed new cables and had to measure to see how long my new longer cable housings had to be. That being said you most likely will not need all new cable housings. I was able to reuse the longes housings up front. The ones that run between the shifters and first cable hangers on the frame. As for the brake lines. On my guardian, the brake lines were way long from the factory. Even after swapping to the larger from the lines could still be shortened up a bit. I hope this helps. Good luck.
  1. Replies: 30
    Last Post: 03-25-2016, 05:03 AM
  2. 2003 spec frames swap
    By monkeyjf in forum Bike and Frame discussion
    Last Post: 08-20-2014, 12:46 PM
  3. Replies: 0
    Last Post: 08-07-2014, 11:52 AM
  4. Parts swap
    By OldHouseMan in forum Oregon
    Last Post: 05-16-2014, 06:19 PM
  5. Parts Swap?
    By Thatshowiroll in forum Cannondale
    Last Post: 08-29-2012, 07:59 AM
