Evo tubeless question- Mtbr.com
Results 1 to 5 of 5
    Just received my Evo and was interested in going tubeless but having trouble getting one of the beads outside of the rim to remove the tube. Does anyone have any tips that wont scratch up my rims?
    On a side note of going 1x10 has there been a standard size NW ring people are going with? I think I have seen a lot of people going for the 32t?
    Apr 2014
    Quote Originally Posted by bbrad View Post
    Technical Tuesday: How To Fix A Flat Tire - Pinkbike
    Check out the link above... It's from Pinkbikes tech tuesdays on how to change a tube and should help you out.
    I am running a 30T chainring and its awesome. I ride in the southeast and there is a lot of climbing so I opted for the 30T. I still find my self pushing the shifter hoping I have one more gear left, but my legs have gotten a lot stronger since I've made the switch to 1x10.
    Thanks for the link. I ended splitting a wooden clothespin into 2 to use as a tire lever, it worked perfect.
    Not sure what size NW I would need in central FL not much climbing, just the occasional patch of sand.
    Sep 2014
    I just moved to FL from GA an I run a 32t on my Evo. I had no problems in GA so I think I'm good here.
    Did you need spacers? or just bolt it on and good to go?
  1. Tubeless question
    By noonievut in forum Wheels and Tires
    Last Post: 02-12-2014, 08:46 AM
  2. Tubeless question *pic*
    By Alias530 in forum Wheels and Tires
    Last Post: 10-10-2013, 09:24 PM
  3. Tubeless Question
    By haloblue in forum General Discussion
    Last Post: 09-27-2013, 08:07 AM
  4. Tubeless question from tubeless newb
    By johnb in forum Wheels and Tires
    Last Post: 05-13-2013, 11:25 AM
  5. Tubeless Question
    By CrozCountry in forum Wheels and Tires
    Last Post: 08-17-2011, 07:10 AM
