Chain comes off cassette- Mtbr.com
Results 1 to 7 of 7
    Feb 2015
    I had my LBS perform a full tune up before my first ride on my new evo about 2 weeks ago. On my last two rides my chain has come off the cassette, falling in between the cassette and the chainstay when I'm rapidly shifting thru gears. Any idea why this happens? Should this be fixed by the LBS that did the tube up?
    Aug 2014
    Did they just do the tune up? If so I would just bring it back to them and tell them what is happening. They should resolve it for free.
    Sounds like just an derailleur adjustment issue. The high limit screw probably justs needs to be adjusted to move the derailleur in a little to keep the chain on the cog.
    '15 Niner Jet 9 Carbon
    '19 Karate Monkey
    Motobecane Boris
    Raleigh Willard 3, Furley & Militis 3 (SS)
    Nashbar Carbon Road
    Feb 2015
    Yep, the did the tune up last Sat.
    Sep 2014
    Sounds like a limit screw adjustment like mentioned above. The shop should do it in about a minute.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Or look up a video on adjusting an RD and do it yourself so you're familiar with how it's done. It's not difficult.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Aug 2014
    Quote Originally Posted by Glide the Clyde View Post
    Very true learning to do this level of maintenance yourself provides you with some good knowledge that can save time and a trip to the shop. A little clockwise turn of the H limit screw on the derailleur should solve your issue. Much easier if you have a workstand so you can spin the crank and shift to test without having to ride it. Very easy should take less than a minute to do.
    '19 Karate Monkey
    Motobecane Boris
    Nashbar Carbon Road
    Feb 2015
    This sounds like an easy fix. I'll give it a try.
  1. New chain and cassette and still chain skips under hard pedaling.
    By red913 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-28-2015, 09:46 AM
  2. Replies: 9
    Last Post: 07-04-2013, 01:25 AM
  3. Chain/Cassette Wear After Chain Stretch
    By biggrumble in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-30-2012, 12:21 PM
  4. Chain skipping- new rear derailer, cable chain and cassette already in place
    By Master Obiwan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2012, 08:06 AM
  5. Newb: need advice on replacements for chain rings, cassette and chain
    By Porschefan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2011, 01:53 PM
