Broken Shifter- Mtbr.com
Results 1 to 5 of 5
Thread: Broken Shifter
    Mar 2015
    Broken Shifter
    I took a good spill yesterday on my ride and broke my front X7 shifter on my evo. I need your opinions on what I should do:
    1- remove the front shifter and keep the front derailleur as a chain guide.
    2- replace front shifter with one just like it.
    3- Change out to a narrow wide single front ring. While this option sounds good, I am not too familiar with what I need to get. Do I need spacers? new bolts? Anything else that I should be aware of to mount on to the X7 cranks?
    Thank you all for the help.
    Sawyer Gnome
    Reputation: Nuzzy's Avatar
    Quote Originally Posted by moroccanjoe2 View Post
    Well, that depends... Do you want 10 gears and the slightly reduced weight, or do you want the extra highs and lows of the 2x10?
    Derailleurs are cheap, but so is the narrow wide.
    Evil The Following
    Raleigh XXIX SS
    Replace shifter.
    Reputation: BigDaddyFlyer's Avatar
    I'd replace the shifter. If you live anywhere hilly you'll appreciate the wider gear range.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    For what it's worth I converted to a 1x10 by keeping the 24 up front, replacing the big ring with a bash guard and installing an n-gear jump stop. I ride in a *really* hilly area and don't care about spinning out on down hills but need the 24 up front for the ups.
    So far it's worked great but it may not work for your area. I hadn't shifted into the big ring in months.
  1. How to fix a broken shifter cable mid-ride
    By mtbmatty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-22-2015, 04:56 PM
  2. Alfine 8 Shifter Indicator Broken
    By Corporal Punishment in forum Internal Gear Hubs
    Last Post: 02-15-2014, 07:35 PM
  3. Broken shifter and my options!?
    By cambum in forum General Discussion
    Last Post: 09-13-2013, 08:52 AM
  4. Broken shifter
    By Specialized2k10 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-31-2012, 10:34 PM
  5. Broken Sram X3 Trigger Shifter
    By Wolfie1992 in forum Beginner's Corner
    Last Post: 08-05-2011, 01:41 PM
