Airborne B-29 Help !!- Mtbr.com
    29er Pilot
    Reputation: Disco_Inferno's Avatar
    Does anyone by chance have the geometry on the B-29 Large frame, I'm being asked a thousand questions I don't have the answers too. Any help would be appreciated.
    If Huffy made an airplane, would you fly in it?
    nor sure where to get info on the airborne but you could check with vannicholas.
    www.vannicholas.com
    He was the euro distributor for airborne before they went under. He redisgned the lineup a little and relaunched under his own name.
    They might still have specs for the older stuff and the their Tuareg 29er looks identicle to the b29.
    29er Pilot
    Thanks, thats a good start.
    Reputation: 29erdownunder's Avatar
    Aug 2005
    Here's the specs for a large '03-'04 B-29
    In Inches: Actual TT-23.75, Effective TT-24.64, H/T angle 71 Deg,, S/T angle 74 Deg, H/T length 4.33, Wheelbase 42.64, B/B drop 6.3, C/S length 17.8, Frame weight 3.85 lbs. Quite respectable numbers I have to admit. I used to be an Airborne dealer. This is right out of the catalogue.
    Mike
