XCT Suntour Upgrade (29er)- Mtbr.com
Results 1 to 2 of 2
    May 2020
    Hope XCT Suntour Upgrade (29er)
    Hi All, i have a Specialized Hardrock 2014 (29er with mechanical brakes) which includes an XCT Suntour fork (80mm i think).
    As i'm getting back in to trails, and my fork has had its day, i would like to upgrade to an air suspension (looking at rockshox) but there are so many choices and I was wondering if anyone can recommend me one? as i'm not sure what spec to go for other than i've heard i can go 20mm up or down, so will be looking at 100mm.
    My budget is around 200-350 and i'm in the UK.
    My current spec if that helps is:
    SR Suntour SF13-XCT-MLO 29", coil/MCU spring, 1-1/8" steel steerer, mechanical lockout w/ preload adj., 28mm stanchions, post-mount disc, 80mm travel.
    Any help would be much appreciated.
    Reputation: NorCal_In_AZ's Avatar
    Sep 2019
    So you need a straight steer, not a tappered. I'm also going to guess that your wheel uses 9mmQR axles, so that will also come into play.
    Something like this may fit your needs https://www.sram.com/en/rockshox/models/fs-30g-rl-a2
    You can also on some bikes get a new headset which will allow you to run tapered forks. Your options will open up then.
  1. sr Suntour xct v2 and SUNTOUR - M3030 DS 26
    By Vuksan in forum Shocks and Suspension
    Last Post: 12-21-2016, 08:58 PM
  2. Suntour XCT Upgrade?
    By anthdan in forum Beginner's Corner
    Last Post: 08-23-2016, 09:40 PM
  3. Suntour XCT to Suntour Epicon XC upgrade
    By beavis87 in forum Shocks and Suspension
    Last Post: 06-09-2014, 12:10 AM
  4. Haro Flightline with Suntour XCT-V4 fork. Choices for upgrade?
    By MustangDan74 in forum Shocks and Suspension
    Last Post: 05-04-2014, 07:56 PM
  5. How should upgrade from my suntour xct fork?
    By jake ninehouse in forum Beginner's Corner
    Last Post: 01-04-2014, 08:57 PM
Members who have read this thread: 13
