Want beefier forks for my 2017 Yeti ASR 29" - Non BOOST- Mtbr.com
Results 1 to 13 of 13
    DenverFletcher
    Oct 2018
    Need you experts out there to advise me. I got a used 2017 Yeti ASR recently but the stock 32 100mm forks feel flimsy to me.
    Would like some 34's @ 120mm... I am 210 lbs with gear if that matters.
    I'm willing to invest some cash into this if i can get the right answer.
    IMPORTANT fact is that this is a non-BOOST frame. I had a guy recommend the Fox Stepcast 34's which look awesome, stiff and light, but I'd have to get a spacer/adapter kit for that. I'm not sure if that is a good idea or not.
    If not, I can't seem to find Fox non BOOST Stepcast, I don't think they make those.
    Totally open to other brands and ideas.
    Reputation: Fairbanks007's Avatar
    Wouldn't one of these work?
    https://www.jensonusa.com/Fox-34-Float-Factory-29-2019
    I think the travel on this one can be reduced to 120mm
    https://www.jensonusa.com/Rockshox-Pike-RCT3-29-Fork
    Reputation: Myers005's Avatar
    Jan 2011
    Stepcast is boost only. You can pick up a used non-boost Fox 34 or Pike on Pinkbike Buysell; Iíve bought several forks there with no problems
    Reputation: Lone Rager's Avatar
    Dec 2013
    I have not heard of issues using boost adapters on a front wheel, essentially 5mm spacers on each side of the fork axle and a spacer under the disc.
    Or get a new boost front hub or wheel?
    What, me worry?
    DenverFletcher
    Oct 2018
    Looks like it, as long as it is non-BOOST. My only concern is that it might slack out the front end a good amount. It's hard for me to be able to determine to what degree that could happen. How can you tell?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    The general rule is that 20mm of additional A-C length is equal to 1 degree.
    And, FWIW, most ASRCs Iíve seen run a 120mm fork. Iím running mine in pro XC racers at 120mm. It improves handling over 100mm, IMO.
    Death from Below.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    The only way to get two forks on there is going to be some sort of arrangement like pictured below, but a fork like this is just way too much for your ASR, so I recommend just one fork. There was the SID XL way back in the day, but again, putting two forks on there is just redundant.
    DenverFletcher
    Oct 2018
    Are you here all week?
    Here you go:
    https://www.pinkbike.com/buysell/1761876/
    Great fork, brand new, non-boost.
    Shartacular Spectacular
    Reputation: Shartist's Avatar
    Aug 2018
    Want beefier forks for my 2017 Yeti ASR 29" - Non BOOST-5805ac29-471b-4cde-8353-2a112a298c42.jpeg
    The beefiest non-boost forks out there, no question.
    18í SC Bronson C
    Grip2, Reserve 27's, i9, Float X2
    18' SC V10
    Fox 40 w/Avy air/coil, WAO: The Outlier, i9, Avy Woodie
    Quote Originally Posted by Shartist View Post
    It's even a pair of forks.
    Reputation: Rngspnr's Avatar
    Feb 2016
    This one here. Super stiff and you can upgrade to a Charger or Avalanche for more tune ability. If you get the charger damper you'll have a Lyric at a much cheaper price.
    https://www.universalcycles.com/shop...RoCYVsQAvD_BwE
    https://www.ebay.com/p/Rockshox-Damp...7194002&chn=ps
    2016 Evil Following V1
    2016 Dartmoor Primal+
    Feb 2015
    If you're willing to step off the Fox or Rockshox bandwagon, consider the Diamond forks by DVO. I have run several Fox and RS forks on previous and current bikes, and the DVO forks are impressively better... in terms of tuning, ride quality, and are totally user serviceable. I currently run DVO Diamonds on my trail and enduro bikes. They are truly incredible forks built by some really smart dudes at DVO. If you need setup/tuning help, you can speak directly with the engineers and technicians. Highly recommended!
  1. 2017 Intense Spider Boost or non Boost?
    By party_wagon in forum 27.5
    Last Post: 03-15-2018, 06:09 AM
  2. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  3. 2017 Yeti ASR vs 2017 Rocky Mountain Element.
    By Ksanman in forum General Discussion
    Last Post: 03-13-2017, 08:32 AM
  4. Why are Fox forks so much beefier (looking) than RockShox?
    By Master Slater in forum General Discussion
    Last Post: 06-10-2013, 01:55 PM
  5. Forks, Forks, Forks, Forks, Forks, Forks
    By Ben12321 in forum Beginner's Corner
    Last Post: 05-04-2008, 05:01 PM
