Update Sram SX eagle on GX- Mtbr.com
Results 1 to 3 of 3
    Oct 2019
    I want to update the transmission and replace the Sram SX eagle with the Sram GX eagle, if not all, but at least the rear derailleur and shifters. Dear participants of the Russian bicycle forums and some masters in my city, they said that it is difficult because the GX on the Boost system, the Cannondale Trail 3 frame is such an update that you need to change the wheel and turn a separate hub under the XD drum. I want to know if anyone has updated the SX eagle on the NX eagle or GX eagle?
    Reputation: LewisQC's Avatar
    Jul 2013
    To run a SRAM GX cassette you need an XD driver. I did a quick look and your bike is spec with Shimano MT200 hub but I'm not sure there's an XD driver available. Usually, it's around 75us$ to change the driver.
    To me, I see no reason a GX derailleur and shifter wouldn't work on your bike if you keep the sx cassette or even "upgrade" to Nx cassette which uses the same driver than SX. But I don't own this bike and maybe I'm missing something?
    2015 Salsa Blackborow 1
    2017 Devinci Hatchet Carbon
    2009 Spec Tricross Sport
    2019 Ibis Ripmo
    Jan 2009
    Quote Originally Posted by Ponik78 View Post
    GX Eagle derailleur and shifter is a straight drop in replacement. Go for it!
    ...they said that it is difficult because the GX on the Boost system
    Your frame has Boost spacing on quick-release dropouts. Boost effects the chainline, so if you want to replace the crankset too, just get the "Boost" GX version with its -3mm offset chainring. It looks like you have a 73mm threaded BSA bottom bracket, so get the corresponding DUB bottom bracket:
    https://www.servicearchive.sram.com/...om_bracket.pdf
    ...you need to change the wheel and turn a separate hub under the XD drum. I want to know if anyone has updated the SX eagle on the NX eagle or GX eagle?
    I would run the stock hub with its HG driver and SX cassette (or NX cassette or SunRace cassette) until you decide to get new wheels some day in the future.
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
  1. Swap from GX Eagle (12spd) to GX 11spd - Cassette Depth Differences
    By sturge in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2020, 11:36 AM
  2. Sram SX Eagle vs. GX Eagle (any experiences/theoretical considerations)?
    By BasRice in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-05-2019, 08:08 AM
  3. Sram GX eagle vs XO1 eagle derailleurs ?
    By Muddy-Runs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2019, 12:17 PM
  4. SRam GX Eagle VS GX Eagle DUB VS SRam GX 1400
    By lqbweb in forum Components
    Last Post: 04-13-2018, 02:10 AM
  5. Replies: 5
    Last Post: 10-10-2017, 02:07 AM
Members who have read this thread: 57
