Trek X-Caliber handlebar cut or replaced?- Mtbr.com
Results 1 to 12 of 12
    Reputation: RobertSalvador's Avatar
    Jul 2014
    Idea! Trek X-Caliber handlebar cut or replaced?
    I just recently purchased a Trek X-Caliber 8 this month, but the handlebars are extremely wide for my taste. I ride sigletrack trails with dense trees and constant obstacles in the way. Is it better to replace my Bontrager Low Riser, 31.8mm, 15mm rise handlebars or could I get away with cutting a few inches off the bars? How much cutting would be a good fit?
    Biking and Hiking that's my therapy! :cool:
    Follow me on Instagram: HARDCORE_RT
    http://instagram.com/hardcore_rt
    RAKC
    Reputation: tigris99's Avatar
    Only u can know how wide u need your handlebars. U can always cut handlebars shorter but how much is up to u.
    I would say ride it more because last I saw stock bars are rather narrow to begin with. Take the time to get used to it. Then see if u really want narrower bars. I ride trails that are densely wooded with obstacles and all that and I got a wider bars not narrower. Narrow bars can make a 29er difficult to control on the rough stuff.
    Sent from my Nokia Stupid Phone using Tapatalk
    I am going through the same thing...but I bought some riser bars instead that are actually even longer then the Bontrager low-Rise.
    My opinion is to get a set of grips with locks on both ends and move them in/out over a couple different rides. Determine what the ideal width is for you and then cut the bars to that.
    Jan 2013
    Ride for a few weeks/months first. There are advantages to wider bars and you might have more room between trees than you think. Stop in some of the gaps and see if you have a few inches or a few feet. The gaps might feel narrow.
    Or they might not. We have some gaps that are just a few inches either side of the bars if you come straight through the gap here. I cut mine down from 700 to 660 after ~ 8 or 9 months and I love them. If your bars are alloy, then just cut the ones you have. If you don't like them cut, go look for a different pair.
    Had the same problem with my Camber Comp, dremel with carbon fiber wheel 1.25" on each side and never looked back.
    2012 Specialized Camber Comp 29er
    Trek 9800 OLCV, XT upgrade 26er
    KHS Fleetwood
    Schwinn 20" Fastback 5 speed stick shift
    Reputation: Sickmak90's Avatar
    May 2012
    You should be able to cut aluminum bars with a tubing cutter made for plumbing.
    Take off 1/2" from each side, then ride it and see what you think. You can always go shorter but you can't add it bAck.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Quote Originally Posted by tigris99 View Post
    ^ This give it time.
    Quote Originally Posted by Sickmak90 View Post
    ^ This is what I would do a cutter is cheap and comes in handy.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Reputation: racebum's Avatar
    Mar 2013
    one of these little guys Shop Kobalt 1/8-in to 1-1/8-in OD Copper Tube Cutter at Lowes.com
    will work perfectly on the bars. if you have the same bar that comes on the lower end superflys it's fairly wide, 690 or 700mm if i remember right. chances are you will have 10mm lines on the bars when you remove the grips. i'd start with just 10mm off each side as that makes a pretty substantial difference
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    The stock trek bars are almost as narrow as I'd go on a 29er. My Cobia came with 690mm wide Bontrager Flat bars. I ride in tight trees and obstacles, but once I rode the narrowest sections slow, I got used to my new 735mm wide bars and I can clear even the narrowest tree sections.
    It takes time to get used to wider bars, and when you get used to them you will wish you never cut them down.
    Dropping into a trail
    2019 Rocky Mountain Instinct A50 BC
    2019 Salsa Timberjack SLX
    2014 Trek Crossrip Elite
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Re: Trek X-Caliber handlebar cut or replaced?
    Stick with the wider bars for a while, they take some getting used to. If you absolutely positively can't get used to them, cut them down no more than 1/2" at a time with a pipe cutter. Its much easier than a hacksaw
    Just to repeat what one guy suggested above, as I did this recently myself: on many lock-on grips they have end caps that can be removed so you can slide the grip all the way down the bar and lock the grip in place with extra bar sticking out the end. Try this before you do any cutting. You may decide that you don't want to cut, or you wil cut but you will have found exactly where to cut.
    May 2013
    I wish I could try bigger bars, but damn I love sliding through narrow trees without braking and losing speed. Have no problems handling corners with shorter bars and slightly longer stem. But if I rode on faster trails where narrow trees didn't exist I would def go longer bars.
  1. Trek Superfly 5 vs Trek X-caliber 2013
    By Inamik75 in forum 29er Bikes
    Last Post: 06-15-2014, 12:09 PM
  2. trek caliber 650b .....trek belgium
    By pilo98 in forum Trek
    Last Post: 06-02-2014, 06:54 AM
  3. Replies: 6
    Last Post: 03-03-2014, 11:44 AM
  4. 2012 Trek X-Caliber OR 2013 Trek Cobia?
    By gofastgt in forum Trek
    Last Post: 11-21-2012, 09:53 PM
  5. 2012 Trek X-Caliber OR 2013 Trek Cobia?
    By gofastgt in forum Beginner's Corner
    Last Post: 11-14-2012, 04:34 PM
