Strong 29er Wheelset. Miche XM40 29 Wheelset VS Mavic TN-719 wheelset 29'er XT- Mtbr.com
Results 1 to 7 of 7
    Feb 2014
    Im a very heavy rider and I am looking for a 29er wheelset that will stay tru under 290 lbs of hard riding. The rear wheel must be 9mm standard quick release. I ride an ON ONE Inbred 29er.
    none at home in Essex, Vermont, United States - photo by nouser - Pinkbike
    I have narrowed it down to Mavic TN-719 wheelset 29'er XT Mavic TM 819 Wheelset 29'ER XT Rear WTB Front 20mm | eBay or Miche XM40 29 Wheelset Miche XM40 29 Wheelset | On - One
    My budget is around $300. Please Help
    THANKS
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Contact MikeSee on the boards here. He is a well known builder and also a clyde so he knows how to build the wheels for the like.
    Feb 2014
    I dont think I can afford his wheelsets....I was looking for some retail wheelsets....I really only need a strong rear wheel. My front wheel runs tru.
    Short-Change-Hero
    Uh maybe talk to the guys over at BicycleWheel Warehouse. Their wheels get great reviews pretty consistently on both the mtb and road bike side.
    Feb 2014
    Aug 2014
    I bought these, only with a front hub setup for a fox fork. I hit jumps and ride hard but I'm only 172~ lbs. A narrow 19mm rim like the 719 may not be a good choice. Wider is better to resist bends. If your running a tire bigger then a 1.95 you shouldn't be using a 19mm rim. If you run a 2.1 to 2.2 you should be on a 23mm and a 2.3 or bigger you should be on a 25mm In my opinion. The wider rim will resist side bends just like a taller beam resists deflection better. SRAM X9 hubs are amazing how well the free spin. I would avoid Shimano XT hubs. Before you even mount them on the bike the don't free spin well. I Bought a set and sent them back when I saw that. I have heard good things about how beefy then 719 rims are though.
    WTB Frequency I23 Mountain Bike Tubeless Wheelset 32h SRAM x9 6 Bolt Hub 26" | eBay
    I think the reality of 290lbs and riding hard is having to save up and get a good wheel like you want. Buying stock machine built is only going to leave you disappointed, especially at the $300 range.
    My .02 is keep what you have as far as the front and contact Mike for a rear wheel only. Then instead of spending $300 on an ok wheelset, you can spend $300 on a rear wheel that will get you what you want.
    Ripley LS v3
    OG Ripley v2 handed down to son
  1. I did not win the Mavic Crossmax 29er wheelset
    By Hawgzilla in forum Off Camber (off topic)
    Last Post: 10-28-2013, 01:15 PM
  2. Replies: 13
    Last Post: 12-16-2012, 02:44 PM
  3. Replies: 10
    Last Post: 12-15-2012, 02:36 PM
  4. Replies: 7
    Last Post: 08-18-2012, 10:49 PM
  5. Replies: 39
    Last Post: 04-02-2011, 02:31 AM
