Stanchion size when changing fork- Mtbr.com
Results 1 to 7 of 7
    Aug 2013
    i have read larger fork stanchions will produce more stiffness. And that axle to crown measurement is the most important consideration. But does moving from 28mm to 30 or 32mm stancions have any other affect on tension on the frame? Thanks in advance
    Stanchion stiffness from diameter and material comes into play the harder you corner and faster you ride. Wheel rim width and construction stiffness contribute and axle/thru-bolt also. Because this is a very direct control performance sport the more precision you have the better. But you may be willing to give some up for the benefits of damping for the suspension component.
    Apr 2013
    +1. Bigger is generally better but like all things its about compromise. How much weight are you willing to carry for how much stiffness. If you demo some different forks you will yet an idea how important this is to you.
    Reputation: Sickmak90's Avatar
    May 2012
    Also take into consideration that an aluminum stanchion will be much lighter than steel.
    Aug 2013
    Thanks for all replies. Crux of issue is this: will moving from 28 to 32mm stanchions put additional stress on frame? I am a beginner with a cheap bike. The headtube is not robust. My intuition made me think the 28mm stanchion fork i have now flexes much more than a larger stancion. This flexing might be absorbing some of the energy. Or i could be a guy who thinks too much w/o a sufficient knowledge base
    RAKC
    Reputation: tigris99's Avatar
    honestly, stanchion size isnt going to matter for the frame. Head tube is going to be stronger than you think. Making sure not to increase axle-crown too much is the most important part. Just dont ride more than the frame can handle. New rider on entry level bike doesnt NOT = jumps and drops more than a few inches and so on.
    Mar 2013
    I went from a Revelation (32mm) to a Pike (35mm) and it was a huge increase in stiffness. The axle went from 20mm to 15mm in the same move so if that makes a difference I couldn't tell if my life depended on it. I'm 240lbs and it's a 140mm fork so 32mm was probably puny for the length and my size to begin with.
  1. Does travel negate stanchion size (Revelation/Slant)?
    By newcasio in forum Shocks and Suspension
    Last Post: 06-15-2014, 08:27 PM
  2. Replies: 10
    Last Post: 03-12-2014, 01:04 AM
  3. Replies: 8
    Last Post: 11-30-2013, 01:05 AM
  4. Does stanchion size affect head angle when all else is equal?
    By tehninjo0 in forum Beginner's Corner
    Last Post: 12-24-2012, 08:02 PM
  5. Oil streaks on fork stanchion
    By santacruz94 in forum Shocks and Suspension
    Last Post: 09-12-2011, 08:24 AM
