Results 1 to 2 of 2
    Sep 2004
    Specialized Hardrock Disc 29 help
    My bike had a striped right crakarn. all the 3 gears are riveted on. basicly one piece Here are my specs. CHAIN KMC X8, 8-speed, w/ reusable MissingLink
    BOTTOM BRACKET Square taper, cartridge bearings
    CRANKSET Samox, forged alloy, 3 pc., 8-speed, 42/32/22T, w/ chainguard
    FRONT DERAILLEUR Shimano Altus, 3-speed, top swing, dual pull
    SHIFT LEVERS Shimano ST-EF51, w/ integrated brake lever
    CASSETTE Sunrace, 8-speed, 11-34t
    REAR DERAILLEUR Shimano Altus, 8-speed
    Here is a link to a new one will it be compatible. I use the bike to ride on flat trails this is a low end one I know I am 58 and just ride for exercise. Shimano Altus FC-M311 Crankset W/Guard | Jenson USA.
    that will work for $21. Just make sure you get the same length arms as your current one (ex: 175mm)
    If you want to go spend more for a better crankset you certainly could bt upgrading to a shimano hollowtech bottom bracket and the newer stuff, but that altus will get you back on the bike. :-)
    for only $30, you could do the acera
    Shimano Acera FC-M361 Crankset | Jenson USA
    and it has replaceable chainrings if needed
  1. Replies: 3
    Last Post: 10-27-2014, 06:43 AM
  2. Specialized hardrock disc 29er or sport disc 29er
    By jeremyreed in forum General Discussion
    Last Post: 01-06-2014, 02:20 AM
  3. HELP? Specialized Hardrock Sport Disc 2013 Mountain Bike?
    By Maca Pittuck in forum All Mountain
    Last Post: 03-19-2013, 09:32 AM
  4. 2011 GT Avalanche 3.0 Disc or 2011 Specialized Hardrock Disc
    By donm3ga in forum Beginner's Corner
    Last Post: 07-05-2011, 07:54 PM
  5. 2011 Trek 3700 Disc vs 2008 Specialized Hardrock Pro DIsc
    By tavorh1 in forum Beginner's Corner
    Last Post: 05-19-2011, 08:52 AM
© Copyright 2018 VerticalScope Inc. All rights reserved.
