Soul Cycles Dillinger -- Build out for under $500?- Mtbr.com
Results 1 to 5 of 5
    Mar 2014
    Hi there, I recently was gifted a 2008 Soul Cycles Dillinger frame and fork (29er). I'm wondering if anyone has suggestions on how I can build it up as a single speed for relatively cheap (under $400-500).
    Some thing to keep in mind:
    I'm about 5'8'' and the frame is 16" (a little small), so I'll need a 400mm seat post.
    I have a seat I can use, and pedals.
    It will need disc brakes.
    I have an old 1999 Trek 6000 that I upgraded with a Shimano XT Hollowtech crank in 2005. Is it possible to take two rings off of that and put it on the dillinger?
    Proudly Plus-Sized
    Reputation: blaklabl's Avatar
    Mar 2011
    PM me I think I can hook you up with wheels and disc brakes well within you budget if interested. Probably tires too, sh*t I got a ton of stuff to build another bike I'd love to part with and not use CL or Fleabay.
    MTBR: Your dad's online mountain bike forum.
    Proudly Plus-Sized
    Mar 2011
    And yes to your crank question it should be just fine.
    Probably doable. You can find wheels for fairly cheap. I've seen WTB Traildiscs (for example) at $100 locally. Then add $50-100 for tires. Another $100 for BB7 brakes (you'll probably need to go used, as you'll need levers as well). Cheap Kalloy seat post is probably $20 and will work fine. New chainring, cog and chain is probably another $100. Use rest for cables/housing and other misc items. You should be able to use your cranks, stem, bar from your old bike.
    With heavy but sturdy parts yes. I've got a set of new Speeddisc I'd ship for cheap. PM if wanted.
  1. MY Soul Cycles Dillinger
    By reydin in forum 29er Bikes
    Last Post: 01-30-2017, 07:43 AM
  2. Soul Cycles Dillinger
    By ub in ne in forum Singlespeed
    Last Post: 07-30-2013, 12:01 PM
  3. Soul Cycles Dillinger?
    By MTSHANK in forum 29er Bikes
    Last Post: 03-12-2013, 04:03 PM
  4. UK 29er project build - Soul Cycles Dillinger
    By pedalcentre in forum 29er Bikes
    Last Post: 01-12-2012, 07:11 PM
  5. Replies: 23
    Last Post: 03-05-2011, 09:25 PM
