Slowing down steering on short offset forks- Mtbr.com
    dmo
    dmo is offline
    Reputation: dmo's Avatar
    I recently was able to get a new Fox34 SC 29er fork with 44mm offset for free so i replaced the old fox32 i had on my xc bike. I havent gone for a proper ride yet but i can tell the steering has quickened up a bit. How do i slow down the steering a little? Wider bars, shorter or longer stem? Would adding more spacers under the stem help at all?
    Sent from my SM-G955U using Tapatalk
    WillWorkForTrail
    Jun 2012
    Wider bars would help some, longer stem could make fit problematic. Consider the possibility of using something like an angleset to slack the head tube angle out a degree or so.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Less offset means more trail, which slows steering and make the bike a little more floppy. Your bike's handling may feel different, but the difference isn't normally called faster steering.
    What, me worry?
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Quote Originally Posted by Lone Rager View Post
    This
    Your steering has more on center feel. If you want to slow down, then longer bars or a longer stem will work.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
  1. Heat slowing you down, or in your head?
    By randyharris in forum Arizona
    Last Post: 05-20-2011, 11:47 PM
  2. Learning how to bunny hop a 12" log without slowing down...
    By willevans in forum General Discussion
    Last Post: 02-14-2011, 08:40 PM
  3. Slowing down on a steep decent?
    By Danny P in forum Beginner's Corner
    Last Post: 01-15-2011, 05:56 PM
  4. Forks, Forks, Forks, Forks, Forks, Forks
    By Ben12321 in forum Beginner's Corner
    Last Post: 05-04-2008, 05:01 PM
  5. Forks, offset, and steering geometry
    By Kolo in forum 29er Bikes
    Last Post: 12-16-2004, 06:28 PM
