Scott Spark pivot bearing not pressed- Mtbr.com
Results 1 to 2 of 2
    Dec 2019
    Hi
    Scott Spark RC Pro 2019.
    I bought it 3 months ago and today I noticed a space between frame and bearing cap on bottom right swingarm bearing (on left side is ok).
    I removed swingarm and saw that on the right side bearing is 1mm in frame and that allows bearing cap to sit but on right side there is no that 1mm space and cap cannot sit to bi in line with frame.
    How that happend or that is probably since beginning and I didn't notice.
    What can I do?
    Attached Thumbnails Attached Thumbnails Scott Spark pivot bearing not pressed-unnamed.jpg
    Jul 2016
    Hi, I had the same problem. You can't press the drive side bearing further because there is like a bump in the metal sleeve you press bearing into. The gap is there on all sparks rc as from what I know.
    Attached Thumbnails Attached Thumbnails Scott Spark pivot bearing not pressed-adnotacja-2020-05-11-173356.png
  1. Replies: 14
    Last Post: 05-22-2015, 11:51 AM
  2. E Thirteen pressed bearing problems on a Ripley?
    By RooHarris in forum California - Norcal
    Last Post: 01-20-2015, 09:21 AM
  3. Scott spark 950 vs Scott spark 29 elite
    By Davidg531 in forum 29er Bikes
    Last Post: 09-17-2014, 08:24 PM
  4. Replies: 8
    Last Post: 03-24-2013, 07:04 PM
  5. FNG Newbie to Pivot - best cranks / pressed fit BB
    By crank-87 in forum Pivot Cycles
    Last Post: 04-06-2011, 06:13 PM
Members who have read this thread: 29
