Results 1 to 8 of 8
    Mar 2015
    Rockshox Reba RL; same model for both 27.5 and 29 wheels?
    Building a XC hardtail 29er and wanting to use a Rockshox Reba RL Fork.
    I am confused about if there are different models for 29 or 27.5 wheels or if the Reba can be used with either wheel size? Some sites list them as 29, some as 27.5 while others list them as 27.5/29.
    I found a deal on a new old stock 2015 Reba's but are listed as 27.5 (120mm 15mm TA 1-1/8"-1.5") ; The crown to axle measurement is 525, which is the same as on my 29er full suspension bike.
    Does anyone know if the 27.5 and 29 the same fork and can be used on either size wheel.
    Always in the wrong gear
    Reputation: ARandomBiker's Avatar
    Aug 2014
    My boost-width 2015 Reba has a sticker that says 27.5+/29 on it. I have a 29x3.0 Vittoria Bomboloni on the wheel. So, the fork is unofficially a 29+ fork, too.
    I donít believe RS makes a 27.5 specific fork. Itís either 26, or 27.5/29.
    Donít modify the trail to match your skills, modify your skills to match the trails.
    Reputation: Joe Handlebar's Avatar
    Apr 2016
    Pretty sure ARandomBike is correct on this. I spent a ton of time trying to figure out a part for my Reba RL and looked through RS' entire manual, etc... and found the same to be true.
    The member formerly known as Redtires....
    Mar 2015
    Checked with Rockshox; according to them different forks for 29er and 27.5; response below.
    "The 2015 Reba 29er will work with a tire width of 62mm maximum (2.44) and overall tire diameter of 755mm (29.72). The 27.5 fork fits a tire of 62mm maximum width (2.44) but in a 710mm maximum diameter (27.9).
    The 29er fork is made for a 29" wheel, and the 27.5" fork is made for a 27.5" wheel. You can't fit a 29" wheel into a 27.5" fork. The 29er fork will fit a 27.5" wheel, but know this will change the geometry and handling of the fork slightly. "
    those sites are leaving off the +. As you found out it's 2 different forks, just some 29er forks are also wide enough to accommodate a 27.5+ tire just like a lot of 29er frames now a days.
    Why would you run a 27.5 on a 29er fork?
    Tallboy 3.1
    OG Ripley v2
    Do you have boost spacing? I think only the boost is officially 27.5+/29. I have a 2018 Reba non boost, bought for a bikepacking fork and haven't weighed because for its use that doesn't matter to me but so far so good nice and stiff for a 32mm stanchion fork. I wouldn't hesitate to recommend one.
    XC, Road, XXC, Endurance, Mtn, All-Mtn, Cross, Gravel, just go have fun on 2 wheels!
    Jul 2016
    I have a sweet RLT TI Reba that I would love to get rid of. Worked over by PUSH Industries too
    Oct 2013
    Quote Originally Posted by TSleep View Post
    I just PMed you about your fork.
  1. Can I Run Both 29/27.5+ Wheels In The Same 29er Fork?
    By Master Slater in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-16-2018, 11:56 AM
  2. Replies: 1
    Last Post: 07-19-2013, 08:53 PM
  3. Same light on both handlebar and helmet?
    By moldau94 in forum Lights and Night Riding
    Last Post: 03-05-2013, 06:27 PM
  4. Need Feedback - 2 Big DH Races Same Weekend - Would you do Both?
    By brado1 in forum North & South Carolina
    Last Post: 06-30-2011, 06:27 PM
  5. Replies: 0
    Last Post: 03-15-2011, 08:27 AM
Members who have read this thread: 37
© Copyright 2018 VerticalScope Inc. All rights reserved.
