Rockshox Pike Select+ charger 2.1 compression questions?- Mtbr.com
Results 1 to 2 of 2
    Sep 2018
    I have a new YT Jeffsy with this Rockshox pike select fork . How do I adjust the low speed and high speed compression? The right side of the fork has the compression damper adjuster but it just says compression +or-. When I rotate it all the way to the stiffest position it doesn't really lock the fork out. This knob kinda feels like I'm adjusting the low speed compression.
    Take a look at the knob in question from the link I provided. The knob cleary says HSC. My fork just says compuression + or -. I'm confused????? How do I adjust the low and high speed compression on this fork?
    Mar 2016
    A little late answer, but you only has lsc on that one.
  1. Charger vs Charger2 vs Charger 2.1. Retune Charger 1?
    By Scottyman in forum Shocks and Suspension
    Last Post: 07-05-2020, 11:57 PM
  2. Rockshox Pike Charger 2.1 Upgrade Compression Adjuster Problem?
    By howie48 in forum Shocks and Suspension
    Last Post: 04-10-2020, 05:32 PM
  3. Pike Select to Pike Ultimate 240lb rider
    By forealz in forum Shocks and Suspension
    Last Post: 03-02-2020, 06:00 AM
  4. Rockshox Pike Select+ Tune vs Damper RC2 upgrade
    By AlDrag in forum General Discussion
    Last Post: 02-11-2020, 06:47 AM
  5. Any reviews of the Lyrik Select and Select + forks?
    By jaks in forum Shocks and Suspension
    Last Post: 11-06-2019, 12:48 AM
Members who have read this thread: 21
