Rigid fork to replace my 80mm Fox fork 29er- Mtbr.com
    I'm looking at a Carver carbon fork to replace the Fox fork on my 2009 Kona King Kahuna (KONA 2009 - King Kahuna)
    It says the fork length is 488mm - would that be exactly the same as the A to C length? Only Carver I found in stock is 465mm A to C so I suspect it is a bit short, though advertised as a 80mm suspension fork replacement. I also assume 1 1/8 straight steerer tube as well.
    Carver also makes a 490mm - the longest fork it makes.
    Thoughts?
    Reputation: seat_boy's Avatar
    The typical replacement for an 80mm travel 29er sus fork is indeed 465mm.
    The 485~490mm long forks are to replace a 100mm travel fork.
    http://www.bikingtoplay.blogspot.com/
    RIGID, not "ridged" or "ridgid"
    PEDAL, not "peddle." Unless you're selling stuff
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by seat_boy View Post
    ^ agreed. I have a 465mm Carver fork for my 2011 Kona Unit, 80mm suspension corrected.
    That said you could probably run the taller fork and slack it out a bit, but I'd want to know how much BB drop that bike has before doing that. Raising the front end too much could make the front light on steep climbs.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: CCSS's Avatar
    If you can run a tapered steerer, I highly recommend the Carver XC470 (470 mm A:C). I ran this on my Krampus, which was spec’d with a 483 mm fork, and it was amazing.
    The Carver guys are fantastic, and their customer service rocks.
  1. 100mm 27.5" fork to replace 80mm 26" fork?
    By drabina in forum Beginner's Corner
    Last Post: 11-07-2018, 07:25 PM
  2. 80mm or 100m? WSD bikes only have 80mm?
    By Bethany1 in forum Women's Lounge
    Last Post: 02-19-2015, 04:40 PM
  3. Replies: 23
    Last Post: 07-05-2011, 07:44 PM
  4. can you replace an 80mm travel fork with a 140mm fork
    By crankbrother in forum Shocks and Suspension
    Last Post: 08-01-2008, 05:30 AM
  5. What length rigid fork to replace 80mm travel fork? Thanks
    By Big Wave Dave in forum Shocks and Suspension
    Last Post: 09-14-2006, 12:18 PM
Members who have read this thread: 22
