Rigid 29er Tires For Colorado?- Mtbr.com
Results 1 to 12 of 12
    Reputation: JMerrihew's Avatar
    Jan 2013
    Idea! Rigid 29er Tires For Colorado?
    Hi there. I have been browsing this forum for quite some time, but I have not been able to find a thread specifically on wide 29er tires for use in sandy, rocky and loose terrain. My Salsa Mamasita can probably Fit a 2.3 rear and a 2.5 front with a Carver carbon fork. A tubeless ready tire is Ideal. If there is a thread already on this, just post a link.
    Josh.
    Reputation: claystrick's Avatar
    Nov 2008
    Tires
    Quote Originally Posted by JMerrihew View Post
    Josh.
    Not rigid but...I've been using the Ardent both front and rear (I think I have the 2.25, but they offer a 2.4) on my RIP9...have Racing Ralphs (2.25 but seem wider) on the hardtail. You should be able to find a tire thread under the Colorado Front Range forum.
    Mar 2011
    tires for rigid
    I don't ride a rigid but for the conditions you mention you can't beat the Maxxis Ardent 2.4 for the front, the back there are a number of 2.25/2.3 tires that work. My current fav. is a Specialized Ground Control 2.3.
    Jan 2013
    Thanks for the suggestion!
    Reputation: azjonboy's Avatar
    Riding a rigid SS in similar AZ terrain. Love the Ardent 2.4 up front, tubeless on a Flow rim at 18 psi.
    Using an old style WW 2.55 on the rear. Wish I could find some old style WW but am currently looking for a replacement for the rear.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
    Specialized Captain 2.2 in front with a Ground Control 2.3 in the rear is a good Front Range tire combo. 2.2 Captain is a great high volume tire, it is a hair bigger than the GC 2.3. If you have nice wide rims, also look at the Specialized Purgatory.
    Reputation: stremf's Avatar
    Dec 2012
    I'm also in the Rockies. My current favorite on the rigid are (front tire only):
    Ardent 2.4
    Rampage 2.35
    Purgatory 2.3
    I'm wanting to try the Ardent on Rabbit Hole rim to see how I like it.
    2.4 ardent in front 2.25 racing ralph out back
    I turn wrenches at a not for profit bike shop in Denver called The Bike Depot
    Dec 2005
    I have found the Nobby Nics provide the best trade off between grip and rolling resistance on my hard tail here in CO. I had Racing Ralph's on before for speed but the could get sketchy if you push the bike hard in braking or hard cornering on our kitty litter ridden trails.
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    Quote Originally Posted by smithrider View Post
    Agree with your evaluation, my experience also. I like the HD in front with the NN rear. The Spesh Control Captain has also done well for me here on the western slope.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Quote Originally Posted by azjonboy View Post
    The 2.4 Ardent works well in the rear, run it ~2 psi higher than the front and you will have plush in spades. The 2.25 works well too, needs ~5 psi more pressure.
    I ride with the best dogs.
    Jan 2013
    Thanks for All of the feedback guys! I have some 2.2 mountain kings on it for now because they were just laying around. Once those wear out, I'll start experimenting!
