NX Eagle Groupset - 165, 170 or 175mm?- Mtbr.com
Results 1 to 10 of 10
    Jan 2019
    Upgrading my Trek with the NX Eagle groupset (have all the tools, install is no problem). But how do you decide the crank length? Is 175 for more speed if you race, 165 for more clearance on trails, and 170 a happy medium? Is there a specific length you would cross off first, if you had to decide between only two sizes? Note that I'm an older clyde who enjoys MTB but by no means am I shredding the desert floor here in AZ, lol. I'm OK with "a little easier" at the cost of performance. Thanks all.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Some bikes run 170mm on small sizes and 175 on M and up.
    If your bike has a low bottom bracket and you're often whacking pedals in rocky terrain, running slightly shorter cranks can add a little clearance but it's not much.
    Unless you're short I'd say go with 175mm.
    I'm running NX 12 on a Merida One Twenty Nine 29er dually and I'm very happy with the 175mm cranks on my size M.
    Less isn't MOAR
    Jan 2019
    Good job! Perfect!
    Quote Originally Posted by Sideknob View Post
    Exactly what I needed to know. Thanks!
    Jan 2019
    And I finally found the specs on my Shimano granny gear stock 3-ring crankset, and it's 175mm. Mystery solved!
    my inseam measures actually 33 inches (I am 5'11"). I have 170mm cranks on my full suspension and my gravel bike. I have 175 on my hardtail. I notice exactly 0 difference.
    I would probably get 170s again because I like that little bit of extra pedal clearance.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Unless you're very tall, go with 170 or 165. Trust me on this.
    What, me worry?
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I run the truvativ descends in 17o. I feel like im less likely to roll my hips side to side when im tired and the shorter stroke means i can put more into the down stroke. I haven't noticed that being shorter they make spinning up harder. I still whack stuff regardless..
    Jan 2019
    ALL great answers, thanks! I wasn't totally sure how significant the 5mm difference would be, and it sounds like it may or may not, BUT, I'll go with the 170mm. Middle choice won't be the risky one, lol. I'm 5'11' w/32" inseam, average height so average crank size.
    I'm the same measurements, no reason not to go 165.
    Ripley LS v3
    OG Ripley v2 handed down to son
    Jan 2019
    Quote Originally Posted by TwoTone View Post
    Turns out that 170 is out of stock in several places. If 165 is in stock then Iíll do that. Iím not thinking I donít want my knees to go that high anyway since Iím getting old. Itís only 10mm but Every little bit helps. 😀
  1. Not shifting into top gear! - Sram NX Eagle Groupset
    By OrangeCrushAdam in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-12-2020, 05:18 AM
  2. Sram NX 1x11 vs NX Eagle 1x12
    By MattBMS150 in forum 27.5
    Last Post: 03-12-2019, 05:00 PM
  3. Replies: 0
    Last Post: 10-08-2018, 12:49 PM
  4. SRAM NX Eagle 12 spd Groupset
    By mevnet in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2018, 08:10 AM
  5. Replies: 5
    Last Post: 05-21-2018, 03:10 PM
Members who have read this thread: 46
