nobody with Di2 ?- Mtbr.com
Results 1 to 20 of 20
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    nobody with Di2 ?
    tried to search , no results.
    have you tried to mount a Di2 group on a 29er ?
    Reputation: limba's Avatar
    I don't remember their names but there's at least two people on this forum using it. One guy races and has been using a hacked version of the original Di2 for over a year. There are random bikes on the internet using it. Tons of roadies and cross riders are using it. The weightweenies site has a lot of smart guys that can answer any questions you have. There's a firmware upgrade so now you can multi-shift.
    I should have my new cross bike (Super X Ultegra Di2) within two weeks. Should be awesome.
    FIRENZE rulez !!
    Di2 su Flash | eliflap
    i made a CNC custom der hanger to solve the problem of RD cage capacity , a big issue with a XX Sram 11-36T cassette ...
    now a little minor adjustement on the hanger and I try to install it on my Flash ...
    what about this issue ?
    similar experiences ?
    Feb 2006
    IMGP8193 | Flickr - Photo Sharing!
    apparently is it possible
    FIRENZE rulez !!
    Quote Originally Posted by tn3845 View Post
    this cassette is not a XX 11-36 ...
    it's a Shimano cassette ....look other pic
    IMGP8200 | Flickr - Photo Sharing!
    Why do you want to use Di2? You're still using a single chain ring set up?
    FIRENZE rulez !!
    mine was only a test for the clearance cassette-RD ... i am coming back to 2x10 set up ...
    i have custom shifters too
    Attached Thumbnails Attached Thumbnails nobody with Di2 ?-20130319-160505.jpg
    I have the hots for it after getting a road and cross bike set up with it last year.
    K-Edge is doing shifters and has a cage for Ultegra Di2....
    It may happen for me this season....and then there's the rumors of XTR Di2 coming soon
    FIRENZE rulez !!
    sure, XTR Di2 is being testing since 2 months from pro teams ...
    but the challenge is to use what is made for other purpose ... :-)
    Eliflap, are you having a problem or you're asking if anyone has done it just to compare builds?
    FIRENZE rulez !!
    Quote Originally Posted by limba View Post
    just check if my direction is right ... comparing some other custom builds
    I'm still in planning stage. I'm running 1x10 and will be using a custom seatpost battery. The fun part I'm working on is running one button on/under/next to each grip. Left hand will shift to a lower gear, right hand will shift to a harder gear. Should keep it simple when I'm blurry eyed, 4 hours in to my epic.
    One thing I would like to see is have the buttons opposed...like new triggers.
    So your thumb would downshift....and your index finger would upshift.
    FIRENZE rulez !!
    mmm , seems to be interesting
    Quote Originally Posted by the mayor View Post
    I bet someone does that. Maybe the new XTR will have triggers/buttons like that.
    since the buttons I'm planning are custom, they could technically live anywhere. One friend suggested I just use the actual Shimano "Sprint" shifters. I was just trying to hold down expense a little.
    I had an old electronic shifter from the 90's. The buttons were pretty small and aligned vertically and about 10mm from each other. Way too close.
    My ideal set up would be rear upshift by the right grip, rear downshift by the left grip and just a single button for the front derailer, a little larger and placed on the left.
    LAN
    LAN is offline
    I have made a lightweight custom 1x10 di2 for mtb.
    I have a completely custom rear harness with 26awg silver wires, heat shrink tubes, and custom battery plug (JST).
    Front haress is stock Shimano, but I have changed the plug to work with Sprint shifters.
    Weight:
    Front harness (contol box) with Sprint shifters: 23g
    Rear harness: 29g (shimano stock is 80g)
    Battery: 16g (shimano stock is 70g)
    RD: Shimano Di2 with Fibrelyte pulleys: 206g
    Total: 274g
    Works great, shift down with right hand, shift up with left hand. Battery is 250mah, but works for a long time, because it's the front derailleur that really uses a lot of energy.
    Attached Thumbnails Attached Thumbnails nobody with Di2 ?-dsc_0009-large-.jpg
    FIRENZE rulez !!
    FIRENZE rulez !!
    Quote Originally Posted by LAN View Post
    Weight:
    Total: 274g
    nice work.
    did you modify the rear harness too ?
