Niner Boost RDO Fork Rack Dimensions?- Mtbr.com
Results 1 to 6 of 6
    Reputation: OneBoot's Avatar
    Nov 2019
    Hey all,
    I'm not sure if anyone on this sub owns the Niner Carbon Boost RDO fork, but I want to use the Tubus Tara Lowrider rack on it. Tubus specifies that the outer width of the fork at the upper mounts has to be between 130-140mm. The lower mounts have to be between 124-134mm.
    Anyone with this fork that can measure those dimensions?
    PDX Living - Commuter and Trail Rider
    2018 Fuji Nevada 1.5
    Nov 2019
    Just spoke with Niner.
    The Top and Mid Upper Eyelets are 150mm apart.
    The lower eyelets are 158mm apart.
    Jan 2019
    So, the Tubus is too small to fit? I have one of those forks, it's on a 853 Jamis steel frame, but its' a QR hub. Mostly it's a "townie" type bike that pedals well and it decently fast, but it's no rocket, that's for sure. But I 've got a BOB rear skewer on its' rear hub and an BOB Ibex trailer, that can haul a whole lotta groceries, and thanks to the cushy ride, I don't think I've ever even broken an egg.
    Sorry, but this is all I got and it really wasn't very helpful. They're great forks though.
    Just call me Ray
    Nov 2019
    Quote Originally Posted by Radium View Post
    Yeah, I crushed my salsa firestarter deluxe by 0.5mm while facing the brake tabs (clamping tool at the co-op had a loose bolt), and am looking for a new fork. The Niner just looks to be of higher build quality. It's also cheaper than the FireStarter.
    Maybe my shop will be able to participate in Salsa's replacement plan (discounted price).
    This bike will be a super-commuter to get me up a 3 mile gravel climb to the burbs, plus trails, etc. I'm envious that the niner works for you!
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Another option..
    Maybe a pannier rack that mounts at the crown and then use a roberts axle project front axle for the 2nd mount. Can you get a rando rack on there?
    Nov 2019
    Quote Originally Posted by jrm View Post
    Unfortunately, there is no crown mount. And now that you mention it, it doesn't even have a fender mount at the crown Looks like I'm sticking with Salsa if I want to commute effectively in the PNW winters.
  1. Fender for Niner RDO rigid carbon fork (the "new", BOOST model)?
    By The_Mickstar in forum Bikepacking and Bike Expedition
    Last Post: 11-11-2018, 01:08 PM
  2. FS 2018 Niner RDO carbon fork --- Boost spacing(110mm)
    By SludgeFactory in forum Classifieds
    Last Post: 08-25-2018, 10:20 AM
  3. Max tire clearance on a Niner RDO boost fork?
    By Walt in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 01-30-2018, 08:16 PM
  4. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  5. Replies: 23
    Last Post: 11-08-2014, 10:33 AM
Members who have read this thread: 16
