New fork for a novice rider- Mtbr.com
Results 1 to 3 of 3
    May 2020
    started riding again after 30+ years (47 now), found a nice looking Kona 2012 Big Kahuna custom build in a local bike shop and started riding. It has a rigid Kona P2 fork (with Panacer 70x43 tires) and my age and lack of skills require some suspension. Mostly ride with my kids around the block on pavement or some light trails in local parks. May start riding other trails in 2-3 years, but nothing serious (no jumps or drops) or super harsh.
    Looking at 3 things:
    1. Suntour XCR LO-R 32 29 found for $69 on Ebay
    2. ROCKSHOX JUDY SILVER TK 29", $169 on probikesupply
    3. RockShox, RECON RL A2, 29'', Solo Air, $249 on Amazon
    Can afford all 3, just wonder with how basic riding I do is it worth it as may not get fully used?
    Thank you in advance.
    The first is OK for bike paths and smooth trails. It lacks adjustable rebound damping and has plastic bushings instead of metal inside. Trails with lots of bumps will wear it out fast. It has a spring inside.
    The Recon uses air to adjust the sag for your weight. It has a compression/rebound damper in one side.
    But damping is rudimentary. It 'll last when riding trails.
    Check the dropouts to make sure your wheel fits. And the head tube on your bike for straight 1-1/8" or tapered.
    If used make sure you're getting a long enough steerer tube on the fork for your head tube.
    May 2020
    thank you for posting the video,very helpful.
    Head tube looks tapered tome, my steerer tube is really long (picture below), I am 6'3" so i am only considering uncut forks,will most likely go new fork because of it. May add a ring or two and don't cut it at all as I like the wheel slightly high.
    How do I know which dropouts will fit the wheel - is this QR?New fork for a novice rider-img_0584.jpg
  1. Replies: 25
    Last Post: 01-07-2014, 10:12 AM
  2. Which 29er for a novice rider?
    By velveteer in forum 29er Bikes
    Last Post: 08-16-2012, 09:22 AM
  3. 29'er and the novice rider - more or less stable?
    By CajunJamie in forum 29er Bikes
    Last Post: 04-15-2012, 03:11 PM
  4. Novice rider moving to Big Bear, CA- need some help
    By alexkak in forum California - Socal
    Last Post: 08-05-2011, 09:17 PM
  5. novice rider - need advice and info
    By schwag27 in forum Beginner's Corner
    Last Post: 06-01-2011, 05:48 PM
Members who have read this thread: 8
