Results 1 to 16 of 16
    Mar 2018
    new 29'' wheelset
    Hi, i am thinking to replace my 29'' wheelset so i could install wider tires.
    For my kind of riding i ended up to these two which both are for max 120kg and ASTM CATEGORY 3.
    https://www.dtswiss.com/en/products/...700-spline-25/
    https://shop.mavic.com/en-int/xa-eli...html#1028=3283
    which would you suggest ?
    Thanks.
    Quote Originally Posted by sotak1 View Post
    Thanks.
    I'd go at least 30mm inner(35 better) to get good performance at lower psi out of 2.35 and 2.4" higher volume rounded profile more modern design tires. So you have to pick the right tire too. A wider rim for the front wheel of say 40mm inner would allow you to experiment with lower pressures and 2.6-2.8" actual width tires. Dt is much better, imo, to Mavic especially considering Mavics use of 'special' parts.
    RAKC Industries
    Jan 2017
    What rims you need is going to depend on tire choice.
    Up to 2.4 tires 25mm inner rims are perfect. 2.4 or bigger(especially bigger) you will want to go wider. FYI though 25mm inner rims are becoming standard width these days. The days of sub 20mm inner width mtb wheels are all but dead.
    Tire profile has nothing to do with modern or not, has to do with tire design. Each is designed more square or more rounded depending on the type of riding they are meant for.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I was running 2.2 and 2.35" tires on 35mm rims for a long time and LOVED the combination. I don't know that I would ever go back to a rim narrower than 35mm ever. MAYBE a 30.
    I like turtles
    I've had wider, very happy with 27mm inners I have on my latest set. I run 2.3.2.5 tires.
    Tallboy 3.1
    OG Ripley v2
    Mar 2018
    i intend to use max 2.35/2.4 tyres on a 29er hardtail
    Quote Originally Posted by RAKC Ind View Post
    Totally incorrect, my friend.
    Many Maxxis 2.35 or 2.4 tires and many Schwalbe 2.35 tires were designed back when 21mm inner width rims were the standard offering by manufacturers. Those designs aren't geared to 30mm rims and square off when you put them on wide rims. A tire like the Bontrager XR2 Team 2.35 has a wider carcass and tread pattern that is wide and more rounded. Put that on a 35mm rim and lower the pressure. It doesn't square off. It doesn't fold over at lower pressures. You get really good traction on a wide rim.
    OP. Ask a Trek dealer about ordering this tire. It's priced pretty low. But it lasts.
    Reputation: Fairbanks007's Avatar
    I had a Mavic Elite rear wheel for less than a month, couldn't get used to the flexy feeling back there every time I cornered. I chalked that up to the 24 spokes. I put a set of Stan's rims, 32H, and DT Swiss hubs and couldn't be happier. FWIW, I'm about 215 pounds geared up.
    RAKC Industries
    Jan 2017
    Quote Originally Posted by eb1888 View Post
    Actually your completely incorrect. Even brand new tires only out the last couple years or so the profile varies widely. I have tires from several major brands. And cam function off more than the XR2.
    The XR2 has been around for some time as well has many other rounded profile tires. And more square profiles designed for plus rims are made now as well.
    Yes some old designs remain, but round versus square has OBSOLUTELY NOTHING to do with how long the tire has been around. Its the intended discipline they are designed for.
    Bicycles aren't motorized
    Reputation: life behind bars's Avatar
    May 2014
    25/30mm inside would serve you well imho, it would also afford some additional protection from rim strikes.
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Just sent a pm, if you have boost, I have a brand new set of 29mm internal carbon wheels I'm selling on classifieds. cheers,
    W
    Ignore him, he cuts and pastes the same thing in every thread about wheels, tires, bikes- anything. I bet he can't wrap his mind around a brand new bike being released that can't 2.4 in the rear.
    Tallboy 3.1
    OG Ripley v2
    RAKC Industries
    Jan 2017
    Narrowest tires I own are 2.8 lol. My plan was just to make the OP aware that tire preference plays a part on how wide of rims to go. Instead created a debate lol.
    May 2014
    Everything on MTBR creates a debate. Or an outright flame war.
    RAKC Industries
    Jan 2017
    Quote Originally Posted by life behind bars View Post
    I spent a few minutes thinking, your right. Never a discussion that doesnt end up with someone upset. Though truly here is SO MUCH MORE REASONABLE THAN SOCIAL MEDIA. Points and opinions here at least have some level of experience or knowledge to them.
    But we all ride bikes. Debates and flaming come from frustrations of mother nature being a bipolar biatch and other things keeping us from riding.
    Rides all the bikes!
    Reputation: Sidewalk's Avatar
    May 2015
    I'm running 2.35 on my 21mm wheels for my XC. 2.6 on 29mm wheels. They both handle excellently.
  1. Replies: 0
    Last Post: 05-03-2017, 10:48 AM
  2. Replies: 1
    Last Post: 12-22-2014, 11:39 AM
  3. Replies: 6
    Last Post: 08-20-2014, 07:36 PM
  4. Used King wheelset vs New Hope wheelset
    By QuickSilverZ in forum Wheels and Tires
    Last Post: 12-16-2012, 11:35 PM
  5. Replies: 16
    Last Post: 06-13-2011, 01:15 PM
© Copyright 2018 VerticalScope Inc. All rights reserved.
