Maximum tire size for a Fox 32 Float 29 Evolution- Mtbr.com
Results 1 to 2 of 2
    Jul 2016
    Hi,
    What is the maximum tire size that the Fox 32 Float 29 Evolution CTD 100mm x 100mm x 15QR can reasonably accommodate? Additionally, if I ran 27.5 inch rims, could these forks accommodate 3 inch plus size tires?
    Also does anyone know what the maximum 29er tire size you can reasonably accommodate on a standard 135mm frame spacing with a 10-speed Shimano groupset?
    Reputation: racebum's Avatar
    Mar 2013
    frame will be limited by the chainstays. a lot of frames will not clear real 2.4" tires, you will have to try them
    fork was designed for a 2.2 or 2.4" tire and can clear either
    if you want to go slow & fat that's a different frame and something like a bluto for a fork
  1. Replies: 5
    Last Post: 07-18-2018, 01:18 PM
  2. maximum tire size on a DT Swiss Spline1900
    By bugdocmtb in forum Wheels and Tires
    Last Post: 07-11-2016, 04:54 PM
  3. Mach 6 maximum tire size?
    By robbieracer in forum Pivot Cycles
    Last Post: 08-29-2013, 05:14 PM
  4. Maximum float.
    By DavidJohn in forum Fat bikes
    Last Post: 08-25-2012, 10:37 AM
  5. Maximum 26" Tire Size Cannondale F7?
    By BarryMcCackiner in forum Cannondale
    Last Post: 08-26-2011, 09:02 PM
