manitou minute fork stanchions internnal scratch- Mtbr.com
Results 1 to 3 of 3
    May 2018
    Greetings every body
    Sorry if am posting in the wrong thread please advice.
    I own a manitou minute comp 29er fork the version with the black stanchions, it was working find, All of a sudden it started leaking air to the lowers and loosing pressure.
    Changed a couple of air piston thinking that i was the problem no joy continues to lose pressure after 2 rides exactly maximum three, after closer inspection i first found the air piston seal to have abrasion marks on a certain point on all piston seals i used the one that was already in when it started loosing air and the following 2.
    After further inspection i found that those piston seal marks are corresponding to internal stanchions scratch.
    1st question: what could be the possible cause that would lead to development of such scratch?
    2nd how to avoid in the future cause i have the same exact fork on another bike ?
    3rd is there a way that i could polish or smooth out those scratches i believe if i did so that would solve the problem
    attached photos of the scratch, fork and piston.
    much obliged
    Attached Thumbnails Attached Thumbnails manitou minute fork stanchions internnal scratch-manitou-air-piston-3.jpg
    manitou minute fork stanchions internnal scratch-whatsapp-image-2020-06-06-6.55.43-am-1-.jpg
    My little friends
    Reputation: EABiker's Avatar
    If the material is missing, (as what a scratch is), polishing would only remove more . That may be toast.
    May 2018
    Quote Originally Posted by EABiker View Post
    Actually it doesnt matter cause in my situation i managed to fit a little bit larger seal around the piston in another fork and it seems to work all i need is an idea which would help to smooth out those scratches cause every time i try to install a new seal those scratches ruins it.
  1. Scratch on stanchions
    By antonyluo5 in forum Shocks and Suspension
    Last Post: 10-04-2019, 02:17 PM
  2. Manitou Minute Pro vs Minute Expert
    By ClemsonCJ14 in forum Shocks and Suspension
    Last Post: 05-21-2012, 04:30 AM
  3. 2011 Manitou Minute Expert vs Minute Pro
    By Robbieisbobert in forum Shocks and Suspension
    Last Post: 09-03-2011, 10:09 AM
  4. manitou Minute 2 vs Minute 3
    By kmandevi in forum Shocks and Suspension
    Last Post: 06-17-2006, 08:34 PM
  5. Upgrade from Manitou Minute 2.00 to Minute 3.00 ????
    By Adventures_more in forum Shocks and Suspension
    Last Post: 04-25-2004, 08:29 AM
Members who have read this thread: 20
