If I get this suspension fork, do I need anything else?- Mtbr.com
    Dec 2018
    Sneaker man
    Reputation: mik_git's Avatar
    Yes that could work... but is it going to be any better than what you have?
    All the gear and no idea.
    Reputation: huckleberry hound's Avatar
    Feb 2015
    Quote Originally Posted by mik_git View Post
    It will be better than what he has. He will be able to set the sag properly to his weight and it won't be an undampened pogo stick like his current fork. That being said it will still have limitations but his bike has limitations as well.
    Change begins by doing something different.
    Apr 2015
    If you're planning on installing the fork yourself, be aware that there a few things involved that should only be done with purpose-built tools that are typically only found in a bike shop, including installing the crown race, sizing and cutting the steer tube,and installing the star nut inside the steer tube. Depending on where you are located, all of that labor may exceed $50 at a shop.
  1. If I get this suspension fork, do I need anything else?
    By reece2002__ in forum 26er Bikes
    Last Post: 12-30-2018, 09:33 PM
  2. If I get this suspension fork, do I need anything else?
    By reece2002__ in forum 29er Components
    Last Post: 12-30-2018, 08:48 PM
  3. This is in my cart.. do I need anything else?
    By jcd46 in forum Wheels and Tires
    Last Post: 05-02-2018, 07:24 PM
  4. Swapping 2x to 1x10 42 tooth. Need anything else?
    By Schwim Dandy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2017, 08:17 AM
  5. Replies: 4
    Last Post: 01-07-2017, 04:20 PM
