HR Disc 29", alloy double-wall, disc, pin joint, 25mm, 36h- Mtbr.com
Results 1 to 3 of 3
    Mar 2019
    Hello All,
    Could somebody tell me if these tyres are 25mm internal please?
    I have the below currently on my bike (stock tyres and rims) but looking at changing the tyres to Maxxis Ardent 2.4 but not sure if I can.
    Specialized Fast Trak Sport, 29x2.0", wire bead, 40TPI
    Cheers
    Neil
    My first guess would be 25mm external but why not just measure the rims? If you don't want to remove the tire just measure the OD, rim walls usually account for a few mm's so in order to be 25mm they would have to have a larger OD than 25mm.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Rim inner width is usually around 5mm less than outer width. Some can be 4 and some 6 and over. Just measure the outside width and subtract 5mm to get a good idea of the inner width.
    What, me worry?
  1. Replies: 11
    Last Post: 03-06-2013, 07:38 PM
  2. Replies: 1
    Last Post: 04-27-2011, 07:55 PM
  3. Swap Code brake pad pin bolt with cotter pin
    By obssesed in forum Brake Time
    Last Post: 07-13-2008, 09:00 PM
  4. 32H Ryno, 36H DelTaco or 36H Ryno?
    By Soupboy in forum 29er Bikes
    Last Post: 11-11-2004, 12:02 PM
