Help stopping brake hose rubbing- Mtbr.com
Results 1 to 12 of 12
    Apr 2016
    I'm having really bad rubbing with my front brake hose on my fork, any ideas how I could prevent this?
    Under the tape the hose actually is rubbing against bare-metal having already rubbed through the paint
    Sent from my SM-G920P using Tapatalk
    May 2017
    Incorrect info.
    Correct info below. Good job chaps.
    Apr 2016
    Quote Originally Posted by robmac48 View Post
    Reroute the brake line so it is in front of that fork brace then it will not touch that part of the fork at all. The brake line is meant to go under that brace and be in front of the CSU. Easiest way would be to unbolt the caliper to do this. You should also consider shortening your brake line.
    Is that what u are thinking?
    The brake line should be shorter.
    I donít like the look of your adjustment either. Is that a reverse arch fork?
    After that white zip tie, Iíd try running the hose along the inside of the for leg and to the front, use a zip tie to secure and then up to the brake.
    There is something about the picture that looks really odd/wrong to me?
    You may need to secure the line to the fork leg at a lower position, using a zip tie, and just bypass that thing that is on the fork, then do the wrap around to the front of the fork.
    Reputation: Redlands R&C's Avatar
    Dec 2013
    No, you should actually run the hose around the head tube, to the reversed arch. It does look a little off at first but is very effective
    Like this. Ignore the rigid fork part, but similar for all reverse arch forks works best in my experience.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Quote Originally Posted by Jason Rides Bikes View Post
    this
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Reputation: pebbles's Avatar
    Jan 2009
    I use 3M velcro on my head tube. Use the hooks part and cut to whatever size.
    Apr 2016
    I'll try that thanks
    turtles make me hot
    Reputation: NYrr496's Avatar
    That little horizontal boss on the backside of your brake arch is to zip tie the hose to as it crosses under your down tube.
    I like turtles
    Apr 2016
    Quote Originally Posted by NYrr496 View Post
    Alright I dident realise it went under and around the downtube and headtube
    Reputation: LyNx's Avatar
    You see that "useless" cable tie spot on the back of the fork arch, it's not there for style or to be useless, it's there for you to cable tie the front brake line to after you wrap it in front of the HT to the DS and then under the DT and along the arch and down the fork leg. If you run it as designed you wouldn't have this issue.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    That looks much better. I'd still pay attention for contact with frame going around head tube. The longish hose may be a better for that route.
    Sent from my moto x4 using Tapatalk
  1. Sram brake hose used as reverb hose.
    By Trailmonkee in forum Bike and Frame discussion
    Last Post: 09-18-2017, 06:38 AM
  2. Replies: 5
    Last Post: 12-05-2016, 08:44 PM
  3. 2012 xtr brake hose same as avid xx hose?
    By mtbpri in forum Shimano
    Last Post: 02-22-2012, 09:03 PM
  4. Hydraulic hose is hose is hose?
    By PoorBehavior in forum Brake Time
    Last Post: 03-24-2011, 07:13 PM
  5. Replies: 4
    Last Post: 02-18-2005, 05:58 PM
