Help! New Crank for pf30 cannondale- Mtbr.com
Results 1 to 3 of 3
    Aug 2019
    Has anyone put an wmg on a cannondale carbon fsi. 83 mm Shell pf30? 30mm cranks.
    https://wheelsmfg.com/386evo-abec-3-bb-black.html
    Having serious problems figuring out standards. Hoping this one will fit but need confirmation.
    Reputation: Lone Rager's Avatar
    Dec 2013
    I've installed a number of these in different bikes but can't recall all the specifics. By the specs, it's the one you need. You do need special wrenches. The flat stamped steel variety work but you have to be very careful and deliberate using them as they easily slip off the thin BB flanges. I'd highly recommend getting a socket type and maybe one flat type. Once the BB is installed, you can leave it in and only replace the bearings as needed.
    What, me worry?
    Aug 2019
    Great! Thanks. It the shell diameter That made me think. Iíll order the socket too.
  1. Replies: 7
    Last Post: 02-21-2015, 09:29 PM
  2. Help with finding the right crank for a PF30 Bottom Bracket on Stumpy?
    By asv731 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2015, 02:13 PM
  3. New PF30 BB and Now Crank Barely Turns: WTF (Wrong BB??)
    By MrEconomics in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-24-2014, 05:23 PM
  4. XX1 PF30 Crank Install Help
    By G-Choro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-05-2013, 08:03 AM
  5. Help removing PF30 crank arms
    By TiGeo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-23-2012, 07:38 PM
