Giant Tracker Giant Sport QR141, loose ball to HOPE Pro 4- Mtbr.com
    Apr 2020
    Hello,
    New to the community so hope you can help,
    I have just ordered a Giant Stance 2 29er, I would love to upgrade the rear hub first to a HOPE Pro 4, I can't find any instruction as to the compatibility or difficulty of the change, can anyone shed some steer on this please?
    Thanks in advance
    WillWorkForTrail
    Jun 2012
    Upgrading the hub involves unlacing all the spokes from the wheel to put the new hub in. The new hub will likely require new spokes as well, unless by some chance the hub flange height is exactly the same between those two hubs. Compatibility wise, you need to look at the hub standard for the bike - is it boost? Get a boost hub. 142? Get 142. Ultimately, you may find it easier and less expensive to buy a new wheel unless you have a truing stand and a spoke tension gauge to rebuild the wheel correctly once you've put the hub in. Alternatively, most shops charge between $50-$100 to lace a wheel.
    Apr 2020
    Thanks for your response, what about the freehubs? the website shows the cassette compatibility with the supplied free hubs but does not list the SRAM SX Eagle, 11x50 which comes standard on this bike, does that mean I need to change that too?
    Reputation: slomtbr's Avatar
    Oct 2010
    You'll need the Shimano HG hub for the SX cassette.
    You may as well upgrade to a 10mm through axle while you're at it.
    Almost = Didn't
  1. converting giant tracker sport hubs to 12 x 142 and 15
    By mtunnah in forum Wheels and Tires
    Last Post: 12-13-2015, 09:55 AM
  2. hub info: giant 'tracker sport'
    By TURBOTWIST in forum Wheels and Tires
    Last Post: 01-07-2013, 04:23 AM
  3. Replies: 2
    Last Post: 11-08-2011, 12:12 AM
  4. Hope Pro 2 or Hope Pro 2 Evo for a new wheelset?
    By cesalec in forum Wheels and Tires
    Last Post: 08-18-2011, 11:11 AM
  5. Hope XC vs Hope Bulbs vs Hope Pro
    By reklar in forum Wheels and Tires
    Last Post: 04-25-2006, 07:37 AM
