Fox Float DPS DZB6- Mtbr.com
    Jan 2020
    Fox Float DPS DZB6
    Hi:
    I have a Fox Float DPS DZB6 and the thread is damage and I cant put air in. My bike is an Orbea Oiz H30 and is new (bought it yesterday). Please, where I can buy that part on the internet?. Thanks.
    g=9.764m/s2
    Reputation: Undescended's Avatar
    Apr 2018
    If you did not buy from a LBS, Contacting Fox directly is the best bet on a new bike...
    Reputation: MSU Alum's Avatar
    The Shrader valve is damaged, correct? If you're sure the thread on the valve is bad, and not the thread on the pump, I believe the valve stem can be replaced pretty easily. I would take it to a bike shop. I bet they can set you up for very little expense. I had a bad internal on mine a few years ago and they replaced mine for free (I just dropped $5 in the shop tip jar).
    Jan 2020
    Hi: i changed the eyelet valve tube for $23. Now everything is fine. Thanks
  1. Fox Float CTD Evolition 2014 vs. Float DPS Evol 2016
    By vmakuc in forum Shocks and Suspension
    Last Post: 09-21-2018, 04:51 AM
  2. Replies: 3
    Last Post: 03-08-2018, 01:29 PM
  3. Replies: 1
    Last Post: 08-25-2017, 06:11 AM
  4. Replies: 0
    Last Post: 06-05-2017, 03:09 PM
  5. 2016 Fox Float DPS vs Float X -> Firm
    By CaRaBeeN in forum Shocks and Suspension
    Last Post: 07-14-2016, 10:22 PM
