Flat tire avoidance- Mtbr.com
Results 1 to 7 of 7
    Reputation: darth biker's Avatar
    Flat tire avoidance
    So I had Ghetto tubes less for a few years, then had to stop riding for another year. I want to get back into it but my tubeless system no longer works. I think I will give up to TL for now and go back to tubes. What are my options to avoid flats from snake bites thorns etc.? Iím a little bit out of the loop. Thank you
    Luke, this is your father's lightsaber. I cut him in 1/2 to get it.
    Jan 2009
    I think you should read the advice in the identical thread you posted in the other sub-forum.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Proper rim tape and tubeless ready tyres and good sealant.
    Less isn't MOAR
    Dec 2013
    Thorn Proof Tubes
    Adding a strip of old tubes between the tube and tire
    Using commercial Tire Liners
    Using tires with extra lining - Schwalbe Marathon Plus
    Using a double wall rim with lots of space between the nipple holes on the rim and where the tube sits.
    Great suggestions, thank you!
    Dec 2013
    As a really really side note - The ultimate flat proof is moving towards motorcycle tires and motorcycle rims, thats what some in the ebike community do. 16" motorcycle rim is 20" bicycle tire, most will use a 19" motorcycle rim which is 24" bicycle size. 20" motorcycle rim is absolete, 21" motorcycle rim is 27 or 28" bicycle size. Not something you want to put on a normal bicycle/analog bicycle because when you start getting into motorcycle rims and motorcycle tires, for ebikes, those rims and tires weigh a ton compared to normal bicycle stuff.
    Bicycle puncture proof - Lots of people go to tubeless, which lots of people seem to have success with. The tire fits more snuggly to the rim, its a special kind of rim that is a tubeless rim. Special prep is needed, special liquid goo is required. The good thing is that you can carry a spare tube with you and use the tube when you get a flat. But the downside is you gotta deal with all that goo and mess.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by matt4x4 View Post
    Something about the way you wrote this tells me that you might not have any idea what you're talking about.
    Either that, or english is not your native tongue.
  1. 50+ Forum Avoidance Reaction
    By Fleas in forum General Discussion
    Last Post: 10-17-2019, 03:01 PM
  2. Tick Avoidance - Wider Trails?
    By Ohio MTBer in forum General Discussion
    Last Post: 06-30-2018, 10:33 PM
  3. Boy Racer Avoidance Passion
    By Slee_Stack in forum Riding Passion
    Last Post: 10-13-2011, 08:46 AM
  4. Saddle sore avoidance tips?
    By BiknMama in forum Women's Lounge
    Last Post: 03-21-2008, 04:45 PM
  5. CSprings Construction Avoidance
    By horax in forum Colorado - Front Range
    Last Post: 03-26-2007, 11:06 AM
Members who have read this thread: 68
