Epic WC fork swap?- Mtbr.com
    May 2012
    Epic WC fork swap?
    To slaken it out a bit
    Fox 32 SC (100mm 55 degree offset)
    Fox 34 SC (120mm 41 degree offset)
    Votes and why:
    Reputation: Lone Rager's Avatar
    Dec 2013
    Longer travel and reduced offset both work in the same direction to increase trail, which favors descending and high speeds over climbing and slow/tight maneuverability. If that's what you want, you're going in the right direction.
    What, me worry?
    May 2012
    Thatís what I was thinking. But... a fox 32 SC is on back order. And throwing a grand at 15 percent change... ummmm. Canceled my order.
    My search for an older RS sid 120 w/same 46 OS but 120. Maybe a RTC3. At a fraction of the price. Or leave well enough alone and save for a dedicated.
    May 2012
    Just received and installed a Sid rct3 120mm. I opted for a late model primarily because the offset (46) was the same at my current Sid Brain 95mm. I didnít want to compound the additional OS with increased travel and lose a large portion of my steering response. I now need to mess with stem length/height after my inaugural run.
  1. 2015 epic wc expert sid swap question
    By man.cave in forum Specialized
    Last Post: 11-19-2015, 10:59 AM
  2. Epic WC chainring swap
    Last Post: 07-06-2015, 12:27 PM
  3. Specialized Epic Expert WC or Elite WC? (2015MY)
    By Alex_Spec in forum Specialized
    Last Post: 06-02-2015, 12:13 PM
  4. stumpjumper sworks wc vs epic sworks wc
    By eliasabourachid in forum 29er Bikes
    Last Post: 08-21-2014, 07:15 AM
  5. Replies: 14
    Last Post: 02-25-2014, 05:07 PM
Members who have read this thread: 27
