Does chain line make noticeable difference?- Mtbr.com
Results 1 to 5 of 5
    Nov 2018
    My hardtail is an NS eccentric 29er, currently running Gx cranks but changing to a shimano drivetrain. I would like to be able to fit a 34 T ring instead of my 32T but clearance is tight.
    My current chainline is 52 mm I noticed shimano make an SLX FC-M7120-1 which has a 55mm chainline instead of 52 so I may be able to fit a 34T
    This changes Q factor from 172 to 178mm, will this be noticeable?
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    You won't likely notice the change in Q factor.
    You're much more likely to notice that your chain drops off the large cog if you backpedal in the slightest. And it will get worse as your drivetrain wears.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yeah. Not a huge deal IMO, but I do prefer a closer in chainline that favors the larger cogs, where I do most all my pedaling. I run non-boost ring/cranks on boost bikes. It is only 3mm diff.
    What, me worry?
    Change your cassette
    GG Shred Dogg 27+/29 (go fast!)
    RSD Wildcat V2 (backyard kicks)
    Pivot Shuttle 27.5 (wifeys)
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by Nurse Ben View Post
    That could be challenging finding a cassette geared to your preference.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. 2 teeth difference chainring, noticeable or waste of money?
    By westin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2014, 09:45 PM
  2. Noticeable Stiffness Difference
    By Mallet21 in forum General Discussion
    Last Post: 12-19-2013, 06:15 PM
  3. Is there really a noticeable difference....
    By glider72 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2012, 03:03 PM
  4. Is there any noticeable difference between the Sram X-7 and X-9 rear derailleur?
    By chuck732 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-09-2011, 02:21 PM
  5. Rim Width - does it make a noticeable difference?
    By mturoamer in forum 29er Bikes
    Last Post: 03-31-2008, 09:32 AM
Members who have read this thread: 90
