Crankset shimano xt m8000- Mtbr.com
Results 1 to 14 of 14
    Oct 2019
    Hi,
    I have crankset shimano xt m8000 2x11 boost. I dismounted both chainrings 26-36 and mounted 32T shimano m7000 dedicated for 1x11. Generally all is running fine with my 11-42 cassette. I have only impression that chain is to curved on highest cogs and wonder if I should add spacers between spider and chainring in front.
    Jul 2019
    Your talking about your chain line? If the 32t is as close to the frame as it can be, then no.
    With any 11s or 12s the chain line on the largest cog bends dramatically.
    Oct 2019
    Hi, yes, about chain line. I can add spacers to close it to the frame.
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    It's up to you.
    Oct 2019
    It's up to me. But how it should be.
    Jul 2019
    Quote Originally Posted by PiotrN View Post
    What gear on your cassette is straight with chain line?
    If its in the middle you are done leave it alone.
    Its normal to have a drastic bend in chainline on 1 X 11 or 1 X 12 on the largest cog
    Oct 2019
    fourth smallest cog. Cassette 11-42 , 11s.
    Oct 2019
    Quote Originally Posted by Outhouse View Post
    I am more often cycling on highest cogs so I think good idea would be to add 1-2mm spacers. Thanks for help.
    Oct 2019
    *largest cogs
    You will need around 2 mm of spacers and longer bolts.
    -Race Face Steel Inner Chainring Bolts 12.5mm set
    -Shimano XTR FC-M9000 Gear Spacers - Y1PV98030
    Oct 2019
    Quote Originally Posted by mit3k View Post
    Hi, many thanks for your post. I already bought longer bolts and used spacers from metal shop. Firstly I used 2mm spacers. Because I have an impression it would work better I added additional 2mm. But it was too much and my crankset failed during ride - bolts were wrenched. So I returned to 2mm. It's good to know there are original shimano spacers available. Thank you.
    Reputation: Rngspnr's Avatar
    Feb 2016
    Your bike mfgr should have a spec for chainline. You want to get your chainring as close to that as possible.
    2016 Evil Following V1
    2016 Dartmoor Primal+
    Oct 2019
    Quote Originally Posted by Rngspnr View Post
    My bike mfgr has 51.8 mm chainline.
    Oct 2019
    According to shimano , 1x11 crankset has 53.4 mm in boost standard. I asked in some bike shops and was told that spacers should not be necessary. However I took some rides with no spacers, 2mm and 4mm and definitely spacers are necessary. I think 2-3mm will be finally enough.
  1. Replies: 7
    Last Post: 06-02-2018, 07:23 AM
  2. Is SRAM 11 spd cassette compatible with a Shimano XT M8000 1x crankset?
    By barenal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2016, 02:12 PM
  3. Shimano XT-M8000 crankset compatibility
    By Ranger Pride in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-15-2016, 06:36 AM
  4. Can I convert a triple 3X9 shimano crankset to a single to use in an XT M8000 1X11?
    By drenzoni in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2015, 06:46 PM
  5. Replies: 0
    Last Post: 06-15-2015, 09:49 AM
Members who have read this thread: 4
