Which chain length to Purchase- Mtbr.com
Results 1 to 12 of 12
    I am about to upgrade to 12 speed Shimano from 11 speed Shimano on my 2018 FS Specialized Epic.
    Most groupsets come with 116 link chains.
    Does the 116 link version fit most dual suspension bikes, or do most people have to use the 124 or 126 link versions.
    This is not a "how do I size my chain" post. it is purely so I don't fit a chain and realise that's it's not going to be long enough.
    thanks
    Reputation: sturge's Avatar
    I've had FS bikes since 2001 (all in an XL frame size) and never bought a chain that was 'special' with more links than a standard chain for the appropriate drivetrain. Once it showed up I always had to remove a few links to set up properly. This includes my current Kona Process 153 which came with 1X12 drivetrain.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by uppo View Post
    thanks
    If you buy a 12 speed chain it will have 126 links so you don't need to ponder much on which length to buy.
    I brake for stinkbugs
    Thanks for the replies. I've told have always had to remove links, but as there are now chains with 124 and 126 links, I wasn't totally sure.
    Most of the groupsets come with the 116 link chain. I'm yet to see one, unless it's a higher priced one, that comes with an option to change it to a longer one.
    Reputation: MSU Alum's Avatar
    As mentioned already, mountain bike 12 speed chains come with 126 links. There are 8, 9 and 10 speed chains that come with 124 links. There are 12 speed road chains that come with 114 links. I've seen other road chains that look to be 116 links. The 11 speed Shimano comes with 116 links.
    Just make sure you get a 12 speed chain for a mountain bike.
    The Shimano XT CN-8100 12 speed chain comes with 126 links. Buy it.
    Or save some money and get the SHIMANO SLX CN-M7100 12 SPEED CHAIN, which also has 126 links.
    If you're going SRAM, buy the SRAM GX Eagle 12-Speed Chain w/ PowerLock. It also has 126 links.
    And as I have already mentioned, I have found 4 piece groupsets that come with a116 link chain. There also shops that sell 116link XT m8100 chains. If you don't believe me then that is ok with me. If you think I'm wrong, google M8100 chains and click on a few shops.
    All i was asking was if a 116 link chain would fit. If you don't have an answer you don't need to answer. Perhaps you could have said something like, "I used a 126link chain and removed 6 links to fit my ?? bike, so a 116l chain could possibly be too short" But you seem fixated on the fact that groupsets don't come with 116 link chains.
    Uppo
    The description of the Groupset you are looking at could have a Typo listing 116 links I have seen several listings that just carried over info from 11 speed components
    I built up an XT 12 speed on an XL Santa Cruz Blur 29'r frame since I bought my XT chain individually (not part of a groupset) it came with 126 links and I removed 6 links.
    I have a 28 tooth chain ring and a 10-42 Cassette and fitted the chain using Shimano's guidelines. On a 2 different medium frame builds I removed 5 links.
    https://dansbikeblog.com/article/how...eed-drivetrain
    I'm not certain 116 links would fit my current drivetrain.
    Quote Originally Posted by teleken View Post
    I think you're probably right about the typo, I bet they do come with 126 links. I wonder about how you counted your links though because you can't remove 5 links, only even numbers. Each rivet is counted as 1 link.
    I have clicked on a few shops and haven't seen anything other than 126 links for an individual chain. As mentioned there might be a typo on the groupset listings, if it were me I'd order without worry.
    No. Get a 126 link chain.
    The responses were attempts to explain to you why that was the case.
    Thanks all for the answers - we finally got there.
    I've just ordered a groupset with a 124link chain for only a little bit more.
    Once it is fitted, i'll report back to see if I have gotten away with the shorter one.
    Uppo
    For the purpose of educating us, what groupset, exactly, did you get?
    Quote Originally Posted by MSU Alum View Post
    M8100, but I will be using a absolute black oval chainring instead of the shimano ring.
    And it is the version that is for the shimano 12 speed chain.
    Uppo
  1. SRAM Eagle chain length, shortened length. Question on setup
    By NorCalTaz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2020, 10:27 AM
  2. Replies: 3
    Last Post: 04-12-2013, 12:21 AM
  3. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  4. Chain length & chainstay length
    By marinrider in forum Singlespeed
    Last Post: 08-14-2006, 05:28 PM
  5. calculating chain length w/cage length
    By Slobberdoggy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2006, 07:43 AM
Members who have read this thread: 60
