Chain guide on Specialized Chisel- Mtbr.com
Results 1 to 2 of 2
    Jan 2020
    is installing a chain guide on a Chisel not an option?
    I am looking at the Specialized Mini Chain Guide but I can consider other options
    Attached Thumbnails Attached Thumbnails Chain guide on Specialized Chisel-img_1905.jpg
    Reputation: Lone Rager's Avatar
    Dec 2013
    It doesn't look like the bike has ISCG tabs that the Spec Mini guide would require. You can find one that clamps around the seat tube (google "seat tube chain guide"), or if you have a threaded BB you might find one to mount under the DS BB if there is a spacer under it which can be replaced by the guide.
    I don't run chain guides on my bikes. Narrow/wide rings and RD cage clutches have greatly reduced the need. Have you dropped the chain or run into situations where you needed a chain guide?
    What, me worry?
  1. Specialized Chisel discussion
    By 04 F2000SL in forum Specialized
    Last Post: 6 Days Ago, 03:26 PM
  2. Specialized Chisel build
    By Limon in forum Weight Weenies
    Last Post: 05-09-2019, 01:17 AM
  3. Replies: 4
    Last Post: 03-18-2019, 11:55 AM
  4. 2018 Specialized Chisel Comp.
    By j102 in forum Classifieds
    Last Post: 07-10-2018, 08:48 PM
  5. Rigid Fork for 2018 Specialized Chisel Comp.
    By j102 in forum Specialized
    Last Post: 04-17-2018, 05:58 PM
