Bontrager XR4 2.4/29 or XR4 2.6 rear?- Mtbr.com
Results 1 to 7 of 7
    Should I swap out my 2019 Bontrager XR3 2.4/29 rear for an XR4 2.6 on my 2018 FEX 9.8? The XR3 2.4 (rear) has been great in CO front range this year but thinking of going to wider XR4 2.6 for fall as the XR3 wears out. Is 2.6 in back going to be a noticeably better climber/traction over a 2.4 XR4 or too heavy for long climbs? BTW, am running XR5 2.6 in front and it's very good. Thanks.
    Reputation: minimusprime's Avatar
    Weight won't be a factor. We're talking about 170g of weight that once spun up, won't make much of a difference. I run the 2.4 XR 4 and a 2.4 XR 3 (new) on my trail bike and I like the combo quite a bit. I think you can't lose out either way. The 2.4 XR4 is an amazing tire for the price, grip, compliance and mileage it'll go before wearing out. If you like the way 2.6 tires feel, then by all means go for the 2.6. Otherwise, shed the 1/3 of a pound and stick with the 2.4. Your choice and totally based on your preferences on this one.
    Reputation: DethWshBkr's Avatar
    I have an XR4 2.35 on my Remedy, and XR4 2.6 on my Prowler. I can't say the 2.6 seems to offer any additional traction under local trail conditions. It does seem more sensitive to pressure though.
    Reputation: brent701's Avatar
    Sep 2012
    Quote Originally Posted by morrison1 View Post
    No,
    run a 2.6 in the front and the 2.4 in the rear
    Too Many .
    Never trust a fart
    Reputation: frdfandc's Avatar
    I would run a XR4 2.6 up front and a 2.4 in the rear.
    Dec 2013
    Don't rule out a 2.6 XR2 in the rear. It's lighter than a 2.4 XR4, provides more cush than a 2.4, faster than an XR4, and has a surprising amount of climbing grip due to its size. I was worried it wouldn't have enough grip for climbing but I have zero complaints.
    Whichever you choose you can try it and if you don't like it return it for a full refund with Bontrager's satisfaction guarantee.
    Trail Rider
    Reputation: mlx john's Avatar
    I've run both on my '17 FEX.
    Con- heavier, a bit slower on climbs
    Pro- can run lower pressure, a bit more traction on tech climbing
    When running bontrager tires these days I go with 2.4XR4 f&r
    2020 Turbo Levo SL Expert Carbon
  1. Bontrager XR3 vs XR4's 2.4 x 29 rear w/ 2.6 XR4's front?
    By morrison1 in forum Wheels and Tires
    Last Post: 04-29-2019, 03:08 PM
  2. Bontrager Tires - XR4 Expert vs XR4 Team Issue
    By V8Interceptor in forum Trek
    Last Post: 02-18-2015, 04:12 AM
  3. Bontrager XR4 29 vs 29-4. Same or different?
    By matto6 in forum Wheels and Tires
    Last Post: 12-23-2014, 03:13 PM
  4. Bontrager XR4 Comp vs. XR4 Team Issue vs. ???
    By bluntrager in forum Wheels and Tires
    Last Post: 10-01-2013, 06:02 AM
  5. DT Swiss XR4.2D vs. XR4.1D
    By emejay in forum Wheels and Tires
    Last Post: 05-26-2007, 09:59 PM
Members who have read this thread: 7
