Results 1 to 5 of 5
    Biggest tires non-boost fork?
    Trying to avoid new fork purchase. Can I run 2.6 tires on Fox non-boost fork? If not, what is biggest tire ?
    Depends on tire, rim ,year and model of the fork. I fit 3.0" tires on a 35 mm rim, Surly Karate Monkey front fork. Start with some measurements.
    Always in the wrong gear
    Reputation: ARandomBiker's Avatar
    Aug 2014
    Almost certainly have no issues with a 2.6. Depending on the year, there are Fox 32's that fit a 29x3.0.
    Donít modify the trail to match your skills, modify your skills to match the trails.
    Thanks for the replies
    Specifically inquiring about 2015 Fox 34 120, Roval fatties (30mm internal). Sounds like 2.6 (regardless of which tire) should be no-issue.
    Am I reading that right?
    Measure width and hight with current tire. Go to the plus forum, see the tire size/ rim posts? There is one with #'s on the maxxis rekon 29x 2.6 thread.
  1. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  2. Fork upgrade dilemma: non-boost vs. boost+adapter
    By Andeh in forum Shocks and Suspension
    Last Post: 11-09-2017, 09:39 AM
  3. Non Boost cranks on Ripley LS with boost
    By marcus_dukakis in forum Ibis
    Last Post: 09-27-2017, 10:56 AM
  4. Replies: 12
    Last Post: 05-01-2017, 02:27 PM
  5. Boost or non-boost fork for 5010v2?
    By furball in forum Santa Cruz
    Last Post: 02-03-2016, 09:10 PM
Members who have read this thread: 19
© Copyright 2018 VerticalScope Inc. All rights reserved.
