Bigger Front tire for my non boost setup- Mtbr.com
Results 1 to 6 of 6
    Aug 2010
    Hey! Iím running 26mm internally measured Stans Arch MK3 29er rims and Iím hoping to get the widest tire I can on there, that still rolls rather quickly. I currently have a 2.4 Ardent. Letís say, if they made a 2.6 or so Ardent, thatís what Iíd be looking at. Anything you know of fit this description? I donít have a ton of brand loyalty and Iíd take a Specialized, WTB whatever. The fork is a Fox Performance 32, 100mm non boost. I imagine my rims might handle a 2.5 or 2.6 pretty well but not much larger. If there is a good rear match for your recommendation, I do have a 2.25 clearance limit back there.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by beardcombover View Post
    Check out the Bontrager XR2 in 29 x 2.6".
    Meatbomb
    Reputation: Phillbo's Avatar
    I run a Specialized Purgatory up front and it works well....
    XR2 2.35 Team front and 2.2 rear with as low pressure as you can manage without rim hits. The 2.35 can use a 35mm inner rim and lower pressure for a bigger footprint and more traction on hardpack with loose. The 2.2 can use a 30mm rim.
    If you go 2.6 you can get performance out of it with a 40mm rim. Less at higher speed and big hits.
    Reputation: MSU Alum's Avatar
    If you like the Ardent up front, you'd probably like the 2.6 Rekon up front. I don't think either one corners worth a darn, but I've run the 29x2.6 Rekon on a 27mm rim and it was okay on the back. Not optimal. For that, you'd be better off with a 30+mm rim.
    What's the reason for the larger tire? I ran a Bontrager XR2 2.6 on both 25mm ID and 30mm rims. 25mm rolled faster (less contact patch) but had less cornering traction. 30mm gave better all around performance. I think Bonti's need 30mm+ rims.
  1. Replies: 11
    Last Post: 04-14-2019, 08:51 PM
  2. Replies: 3
    Last Post: 12-12-2017, 06:43 AM
  3. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  4. Boost to non-boost for SRAM 716 15x110 front hub?
    By Doug in forum Wheels and Tires
    Last Post: 10-12-2017, 05:18 PM
  5. Replies: 0
    Last Post: 04-26-2016, 04:03 AM
Members who have read this thread: 35
